Inventor Forum
sound effects
31 REPLIES 31
Message 1 of 32
1216 Views, 31 Replies
sound effects
does anyone know how to attach sound effects to features. I know when you mate parts there is a wav file with that feature. As a presentation to clients I wnated to attach other sounds to other features, drill noise for holes, elec. sound for welds, etc. is this possible..??
31 REPLIES 31
Message 2 of 32
I did something "similar" but did it through
PowerPoint.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
does
Message 3 of 32
Yep. Take a bunch of snapshots of the part in the same position and turn on
features one by one.
Use powerpoint to fade in these new images (which if placed on top of one
another will look like the same image). Then as you introduce each new
image add the sound effects.
Did a marketing guy put you up to this?
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Keith Bradford" wrote in message
news:DAE68CB115891FFDDC8D1C9854629103@in.WebX.maYIadrTaRb...
> I did something "similar" but did it through PowerPoint.
> "fritsche" wrote in message
news:f17e7b3.-1@WebX.maYIadrTaRb...
Message 4 of 32
well i can do that, but I want to be able to have it happen in Inventor. What i can't find is how the mate feature references the connect wav file in the Bin folder. If i could figure that out I might be able to create sounds for other features. Any ideas?
Message 5 of 32
The best I can think of is to set up your sound effects to run off of hot keys. Run Inventor and when you want the sound effect press the hot key combination for that sound. You would want to set up the sound to run in a small and unobtrusive audio program.
MechMan
Message 6 of 32
stupid question but how do i set up hot keys, is there a directions sheet some where?
Message 7 of 32
One way is to make a shortcut to the sound file, edit the properties of the shortcut and enter in a key combination in the "Shortcut key" area. Another option is to download a 3rd party "hot key" program to basically do the same thing but with greater flexibility.
MechMan
Message 8 of 32
It's hardcoded in Inventor.
Sean Dotson, PE
news:f17e7b3.2@WebX.maYIadrTaRb...
Message 9 of 32
"hard coded"???? is there a set-up keys option some where like on PC games? key config??
Message 10 of 32
Hard coded as in you can't change it. You could use a 3rd party program as
Mech suggested but the triggers that make the sound fire when you mate are
not accessible. You won't be able to do with within Inventor and with only
Inventor.
don't understand what the heck I'm saying>
Sean Dotson, PE
news:f17e7b3.7@WebX.maYIadrTaRb...
games? key config??
Message 11 of 32
so what tells the mate coomand to access that connect wav file?
Message 12 of 32
Look up the word hardcoded...(then reread my post a few more times)
Sean Dotson, PE
news:f17e7b3.9@WebX.maYIadrTaRb...
Message 13 of 32
ah.. http://info.astrian.net/jargon/terms/h/hardcoded.html
Sean Dotson, PE
"Sean Dotson" wrote in message
news:57FF1E3A0DB31397C456CA98486CFBCA@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
Message 14 of 32
The HARDCODE tells it.
so
file?
Message 15 of 32
-do I really not make sense to people? Lately it seems like certain people
don't understand what the heck I'm saying-
Image of PeeWee Herman- what..WHat....WHAT?
Message 16 of 32
i got you now. I am assuming ( i know what assume means) that the hard code is not editable..
Message 17 of 32
i can change the sound of the mate, as long as it is still called connect, is this just a stupid thought or has anyone else thought of doing this, I guess I'm bored
Message 18 of 32
Might start off with using the GNR song "patience" for the sound file.
Message 19 of 32
People have been changing this since it was added.
I like the Homer Simpson "Doh" myself. But machine gun fire is a close
second.
I'm sure if you search the 5.3 NG you'll find
several discussions.
gcooper
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">can
bored
Message 20 of 32
Sure you can rename XXX.wav to connect.wav and
rename and rename and rename.  How important is this ability?  I think
the PP option would be faster, but until we benched marked it I wouldn't know
for sure.  With the PP narrate instead of speaking you could make the
welding sound or whatever you wanted....  You could even paste in an AVI
and synchronize the sound as the
AVI played.  Possiblities are
endless...
can
bored
