Inventor Forum
Sketch will not offset
23 REPLIES 23
Message 1 of 24
1786 Views, 23 Replies
Inventor 2011 will not offset polygon in sketch mode.  I get "Method not supported for transient meta" error message.  How do I fix this problem?  Or what am I doing wrong?
23 REPLIES 23
Message 2 of 24
mrattray
I don't have 2011, but it works fine in 2013. Why don't you post the part file here so I (or someone else) can take a look at it?
Mike (not Matt) Rattray
Message 3 of 24
Select offset, right-click a line, make sure loop select is checked. If you still have the problem attach the ipt and i'll take a look since am running 2011 and can offset polygons or any shape just fine.
left off constraints to show offset lines easier.
Message 4 of 24
blair
Possibly in the Offset, a segment of the line is becomming small enough to that it can no longer exist. This could be the problem as well.
Delta Tau Chi ΔΤΧ
Message 5 of 24
As Blair remarked that is one of the most common problems. Did you make the polygon manually or use the polygon shape tool?
Message 6 of 24
Mark_Wigan
i just had this happen about 2 minutes ago on a simple circle of all things, using inv 2014.
i had to restart inventor and now it is fine.
btw, i have never ever seen this error before now. i was about to post and see if it was a new bug but saw someone else with the same issue on inv 2012 so i cancelled the post, to then see this one running.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
Message 7 of 24
Polygon shape tool was used.
Message 8 of 24
in reply to: Mark_Wigan
Had that happen to me before with projected geometry, but at the time was new to Inventor so just thought it was me. Of course since then have done it many times without any problems, so expect its just one of those rare occurrances that glitch out.
drafdog, have you tried making a new polygon and offsetting it in a completely new sketch? Just to see if it works or not?
Message 9 of 24
mrattray
Have you tried a reboot?
Message 10 of 24
JDMather
Why haven't you attached the ipt file here?
Message 11 of 24
The ipt is part of an exercise in a training text. There are accompanying
files which hold the sketches. I opened their version of the sketch and the
function performed properly. Have no idea what a "transient meta" might be.
"Meta" is not a word, but a prefix meaning (if memory serves) "beyond." I
hate it when code writers pretend to reinvent the English language. Why are
they reluctant to find the correct word? Are they really that lazy?
Message 12 of 24
JDMather
I am lost.
What happens if you
1. start a new file
2. create a polygon
3. try to offset the polygon
Does it work or not?
Message 13 of 24
Repeatedly deleted the polygon and tried to offset new instance to no avail.
Message 14 of 24
JDMather
so why can't you
1. start  a new file
2. create a polygon
3. attach the file here?
Message 15 of 24
Used the shape tool.
Does anyone know what a "meta" is?
"Meta" is not a word, but a prefix meaning "beyond." Why don't people who write code know the English language?
Message 16 of 24
JDMather
I am not familiar with the "shape" tool.  Can you attach a screen capture here?
Message 17 of 24
in reply to: JDMather
he's referring to the polygon shape tool JD
drafdog, download the attached file and let me know if you can offset any of the shapes, or cant for that matter. Trying to figure out if your sketch is perhaps corrupted or something different.
Message 18 of 24
mrattray
Where are you getting "meta" from? What does it have to do with offsetting a sketch entity?
Message 19 of 24
in reply to: mrattray
That's the error they get, why? We don't know yet 🙂 See the attachment from mark_W on page 1
Message 20 of 24
JDMather
@Anonymous wrote:
drafdog, download the attached file .
drafdog indicated using r2011
