Inventor Forum
Single Composite derived assembly/ifeatures
14 REPLIES 14
Message 1 of 15
PACDrafting
401 Views, 14 Replies
I've derived an assembly into a part file.
On inserting an ifeature, Why can't I select a face of the single composite body?
You can create a sketch on a face, but not insert an ifeature on a face....
14 REPLIES 14
Message 2 of 15
PACDrafting
in reply to: PACDrafting
Message 3 of 15
Yong.Jing
Which version are you using?
At my site, there is no any issue as you descriped with Inv2012 Sp1.
It will be much better that you could upload the screenshot or data.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Message 4 of 15
PACDrafting
Did you derive the assembly in as a single composite?
Message 5 of 15
Yong.Jing
You could see the screenshot. Is there something different to yours?
asm drived
Yong Jing
Message 6 of 15
innovatenate
Is it possible that the selection filter is toggling?
Nathan Chandler
Principal Specialist
Message 7 of 15
PACDrafting
in reply to: innovatenate
Tried all selection settings.
Still not able to insert an ifeature on a face of the single composite derived assembly.
This assembly is a frame generator assembly if that helps anymore.
You are able to insert a new sketch on a face but not place an ifeature.
Message 8 of 15
PACDrafting
in reply to: Yong.Jing
Message 9 of 15
SteveMDennis
I consulted with our iFeature experts and they said if you can sketch you should be able to place an ifeature.
Can we get your data to try it for ourselves and try to find the issue for you?
Steve Dennis
Autodesk Inventor Development
Steve Dennis
Sr. Principal Engineer
Inventor
Autodesk, Inc.
Message 10 of 15
PACDrafting
in reply to: SteveMDennis
See attached.
Message 11 of 15
Yong.Jing
The reason of unable to insert iFeature is that you drived the Assemble as surface, not as solid.
After edit it into solid, the iFeature could be inserted.
Insert iFeature
Yong Jing
Message 12 of 15
PACDrafting
Yes I already know that. The reason why I have selected surface is due to large file size with solids.
Anyway, Steve Dennis (Snr Product Development Office) is inspecting this. As he mentioned, you should be able to insert the ifeature as you can insert a new sketch.
Message 13 of 15
SteveMDennis
Sorry I was out on Friday. I am taking a look now and will get the experts involved, Yong and I are in touch as well.
Stay Tuned.
Steve Dennis
Inventor
Autodesk, Inc.
Message 14 of 15
SteveMDennis
PACDrafting,
 OK I see what you are saying.  Upon investigation and consultation with some other developers it appears that when we added composite surfaces we did not augment the iFeature workflow to support them.  This is not possible right now but we all agree it should be.
I have added this request to our database and hopefully we will be able to address this in the future.
Steve Dennis
Inventor
Autodesk, Inc.
Message 15 of 15
PACDrafting
Thanks Steve for looking into this.
QA seems to be an issue with Autodesk at present.
Autodesk Customer Advisory Groups
