Inventor Forum
Sheet Metal Curve Bending
6 REPLIES 6
785 Views, 6 Replies
Hello everybody,
Is it possible to produce this kind of bending and unfold in Inventor ?
Appreciate if someone could help me out. Thanks in advance.
Tags (1)
6 REPLIES 6
salariua
You would be better off to attach you file here. My guess is that you need to use surface and then add thickness to it.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
in reply to: salariua
Hi Salariua,
Please refer to the attached ipt file. Thanks for your prompt response. Look forward for a favorable reply from you.
Tags (1)
IgorMir
Hi Calvin;
I hate to say no, but I have to. What you are after is a case of a plastic deformation. You could mimic the item in the Inventor sheet metal module, but it will be just that - mimicking. And no, there is no need to send the actual file. The picture of what you are after explains it well.
Cheers,
Igor.
Web: www.meqc.com.au
salariua
Contour roll on itself unfolds but you have a deformed shape. Inventor can't handle pressed, punched deformed shapes. Don't know what your manufacturing capabilities are but this is how I would do it.
Check attached.
Adrian S.
blog.ads-sol.com
Hi Salariua,
You can do it this way but still this is not the thing I am looking for. What do you mean by a deformed shape ? Isn't that a normal bend on sheet metal ?
salariua
That's not a bend. What tool would you use and how would you mount it on a press bending machine?
Adrian S.
blog.ads-sol.com
