Inventor Forum
Separate sheet metal parts
14 REPLIES 14
Message 1 of 15
1220 Views, 14 Replies
Hi there,
 I create a bin, but i dont know how to split (separate) 4 sides of bin for plasma cutting machine and then bend and  weld it
What steps i can make to do this ? Please explain me.
Eugene
14 REPLIES 14
Message 2 of 15
JDMather
I would use Derived Components.
Attach your file here for explaination.
Message 3 of 15
in reply to: JDMather
Here is
PS. Something wrong... I cant add a file (((
PS. I did it ,,, ))) because first time i use Intenet Explorer and cant add a file, but now i use Google chrome )))
Message 4 of 15
JDMather
Try this Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
You might also try a different browser (IE, Chrome...)
Message 5 of 15
I added a file ))
Message 6 of 15
brendan.henderson
Try this blog for 1 method of using Derive. If you do it this way then there is no reason to have the 2 Shell features.
http://blh.com.au/#/blog/4572268941/Adaptive-Sheet-Metal-parts-by-using-the-Derive-method/4668391
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 7 of 15
in reply to: brendan.henderson
Thanks for the link,
But this method not solve my question. I already create a model, but now i want to separate each side of model as different metal sheets for plasma cutting
Message 8 of 15
JDMather
How many parts to do you want this separated into? 4? 7?
I noticed that your sketches are not  constrained - so the first thing I will have to do is fix your model.
Message 9 of 15
4 parts- first option
7 parts - second option
Message 10 of 15
Please help me ,to resolve this qestion  🙂
Message 11 of 15
JDMather
First thing I noticed - Sketch1 was not contrianed and it looked like too much work.  (see attached)
I left part of it for you to finish based on what I already done.
Message 12 of 15
Good work, thanks for helping me 🙂
But now the question .... How you do it ?
Message 13 of 15
I am having the same issue.  I have a few parts that i used the shell command on and now need to derive separate parts with compound angles.  How do you do this?
Message 14 of 15
JDMather
I recommend that you start over from scratch.
I don't understand the purpose of all of your Work Planes and Work Points?
 Have you installed all Service Packs and Updates for your version of Inventor?
Do first sketch and then attach the new file here.
You should probably start a new discussion thread here - and only provide reference url link back to this thread.
Message 15 of 15
