Hi I made the mistake that I came to measure my object as cm but inventor writes it's in as mm, is there a way where I can scale objectet up giving it the right size
Solved by JDMather. Go to Solution.
You can go through your Parameters and change all of the dimensions or Derive Component with Scale.
Can you attach the file here?
