Hey there, we have been getting this error coming up on one of our workstations running Inventor 2011 in Windows XP.
The error seems to usually occur when the user is moving apart around or zooming etc in the assembly environment. The workstation has a Quadro 3500 card with the latest certified driver from the Autodesk hardware website. I can't figure out why we are getting the errors. Anyone else been having these issues?
Any luck with finding a fix for this? We have one machine that this happens too. Seems to be happening when the user moves a section view created one one sheet to another. Was just dragging the view in the browser. Then when trying to switch activating sheets it popps up. Any thoughts?
Windows XP, 64-bit. (inventor and vault 2010 still installed)
Thanks.
Hi! Could you post an example here or send it to me? It looks like it is an unhandled exception. If the files are greater than 9MB, I can set up a secure account for you to upload.
Thanks!
Yes it is larger and will need the account to download. I noticed you said secure, so if we could just send it directly to you that would be great. I would prefer not to post it on the internet. Did you need the assembly and part files and everything as well or just the DWG file (inventor dwg)?
my email is kmiller@coldspringgranite.com
Thanks.
In the meantime I did request to our IT staff to have them try doing a repair install.
Hi, does anyone have a clue about that.
One of my customer has the same error on a HP workstation with Inventor 2011 SP1, windows 7 pro x64, and Vault Collaboration 2011 update 2.
This happens when he switches to hidden lines mod in a sketch (part environment).
I just had a user get this error when editing a part file in the context of an assembly. He's running Inventor Pro 2011 SP1 on a Windows 7 x64 machine. Any idea what's up with this?
John Weiss
CAD Administrator
Follett Corporation
Dear Mr. Weiss,
did you find a solution for this problem (Runtime error r6025)? A colleague of us has the same problem. He's running Inventor 2011 on a Windows XP x64 machine.
with best regards
Klaus Spielvogel
MBE Coal & Minerals Technology GmbH
I have the same problem during Autoloader analyse.
Vault 2011, AIP 2011, all up to date.
Any news about this problem ? Any fixes ?
Thanks for tip. But I have the same problem with Inventor 2011 SP2.
My Vault is up-to-date : Update 2 (Version 15.2.66.0).
I have activated advanced log for Autoloader and keep you informed if I have a solution.
Advanced log only informs me about the file that causes Runtime error.
I have an error if i open this file in Inventor.
The only way for me is to exclude these files of the analyse, but it's very long to find them : I have to restart Autoloader each time !!!
If anybody has another idea, I'll test it !
We have a computer that gets this error and it is currently running Inventor 2012, please any info would be helpful
I had this problem (Vault 2011 Update 2) during my Autoloader.
SP1 doesn't solve the problem.
To fix it, I have make the Autoloader with 10% of the data, 10 times, and had no errors.
Do you have the problem using vault ? During installation ? During Autoloader ?
Hi, I'm having this error in Inventor 2011 SP2 (everything is updated). Tried reinstalling everything wishing that this may fix the problem, but with no luck...this problem isn't new and it seems that no one has any solution for it. In Microsoft's support site it says that this problem might be cause due to wrong coding or other coding issues, or due corrupted files (http://answers.microsoft.com/en-us/windows/forum/windows_vista-files/error-r6025/aeb51401-0a1e-4bd6-... which it isn't in my case as I've already reinstalled everything and it didn't help. Also, I understand that r6025 runtime error can be cause due to a registration problem in Windows, so since I haven't tried that and I have no idea how to do that either...can anyone advise on how to do that?
I just switching to 2012 Inventor Pro few weeks and this is the first big drawign that I am opening with 2012 and I got the error (R6025).
I try on other 2 machine and the same error.
In this drawing have 7 sheets and they have some custom view and L.O.D. I thought maybe the .iam need update so I have the assembly open and went thru all the L.O.D and save the assemblt then try the drawing it crash the same with error (R6025)
Now I am worry about other drawing we have created in 2011 format.
Any one or Autodesk has a solution for this please share.
Ps. Win7 64bit sp1
Inventor Pro 2012 sp1 vault 2012 sp1
FX4800 driver 265
48 GB ram
The machine running fine nother other 3rd party software install other than Window surcurity upate
Same Error on same sytem.
When in Assembly and View is Shaded with Hidden Edges:
Panning and zooming wth mousewheel give after a while (few seconds) the Error.
Marco
