Hello.
Is it possible to use/run Inventor from a USB Stick ? Info: it works with FreeCAD
If yes, which versions do allow it?
I need Inventor for simple 3D part design. So the version is not soo important.
Br
Larry
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Sure thing! You can run Autodesk Inventor from a USB stick, but there are some things to keep in mind. Inventor is a bit more finicky compared to FreeCAD when it comes to this. It might work, but performance could be slower, licensing might be trickier, and compatibility might throw some curveballs. It might work differently on various computers, and you might run into speed and compatibility issues. Just keep in mind that it's not something Autodesk officially supports. If you're okay with these trade-offs and just need basic functionality, it's doable. But if you're looking for the full experience, staying with FreeCAD or using Inventor on a regular setup might be a better call.
Ok. Good to know.
Other question: what is the approx. price for older inventor versions on the market? Dont want to spend too much, just need it for drawing of small single parts.
Br
Looking at the Autodesk web store:
Inventor is available at $300/month and Fusion 360 starts at $70/month. Autodesk offers longer contracts with lower monthly costs too.
I'd look at Fusion 360 based on cost. In fact Fusion 360 has personal use and startup license options that Inventor does not.
Steve Walton
Or flex tokens can be purchased and used for Inventor. Search for Autodesk Flex.
Ok. Thanks. Even too expensive for 2-3 mechanical parts per year. E.g. bended perforated sheet etc
Does someone knows guys who sell old (approx. 5 years) secondhand software orginally sealed ? Incl licence
You might have better luck hiring a freelance CAD designer for such low volume work.
Do you need native Inventor models, or can you use any of the open source/low cost programs?
Steve Walton
Personal license of >Autodesk Fusion 360 is free<<.
Warning - do not get suckered into purchasing older version of Inventor from the web (likely no license or illegal crack).
I like drawing myself.
So freelancer not an option.
I have freecad but would prefer Inventor as I used it some years ago.
What about old, sealed cds with key? Illegal?
@larry-leisure wrote:What about old, sealed cds with key? Illegal?
They don't exist for maybe over 10 years?
@larry-leisure
Autodesk products should only be purchased either directly from Autodesk or through a registered reseller.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
I thought that there might be unused software available. I know it from Windows and office CD's. Sometimes you find them on ebay. Original, sealed plus key.
Your best option is to try Fusion 360.
I.... Sometimes you find them on ebay. Original, sealed plus key.
Final warning - do not be tempted.
Saw a few in eBay:
Autodesk AutoCAD Inventor Professional Suite 2011 Portuguese (DVD Only) No Codes
Good luck getting it register.
