With the last update for Inventor, 2018.1.1 it looks like the right mouse button reacts to quick.
Specially when you stille have a little movement in your mouse and use the right button, it selects a command before you have selected the correct one.
Does anyone have the same issue?
Solved by Rob67ert. Go to Solution.
Your problem is odd. I never find any problems in my Inventor after updating to 2018.1.1 and it works good. First you need to install 2018.1 then install 2018.1.1. Feel free if you have any questions.
Some users are experiencing such behavior, such as in this post. There are others, as well.
@johnsonshiue, here's another one.
Sam B
Inventor Professional 2018.1.1
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
Hello, This is known issue (INVGEN-6773) which is under fix validation, and we don't have workaround unfortunately at this moment.
Thanks.
