Inventor Forum
Reason 159 we need a cancel button
10 REPLIES 10
Message 1 of 11
495 Views, 10 Replies
Was promoting a complex surface today. IV did not lock up but I after 10
solid mins it was apparent I still had 10 more mins to go. So I figured I'd
let it crunch on it while I ran some errands later today. So I got to push
the cancel buttons....
Oh that's right. We STILL don't have a cancel button!!!
Shift-Ctrl-Esc, kill process... 😞
Sean Dotson, PE
RND Automation & Engineering
www.RNDautomation.com
www.mcadforums.com
10 REPLIES 10
Message 2 of 11
Sean,
Yes, this is a long-asking wish to have a way to abort an operation without
killing the process. I will forward your request to development for review.
Regarding the complex surface, is there a way you can send the dataset to
us? Are you promoting one by one? Did you try promoting as Composite
Surface?
Many thanks!
Johnson Shiue
Test Engineer
(email: johnsonDOTshiueATautodeskDOTcom)
"Sean Dotson" wrote in message
news:5267589@discussion.autodesk.com...
Sean Dotson, PE
www.mcadforums.com
Message 3 of 11
start smoking... everytime you have to wait for IV go and have a smoke... when you get ill, sue AD for making you smoke so much
Message 4 of 11
Not really, customer is VERY protective. Yes I promoted as a composite.
This part probably had 10,000+ surfaces.
Sean Dotson, PE
www.mcadforums.com
Message 5 of 11
JDMather
Even where there are Cancel buttons they don't respond in a timely manner.
Message 6 of 11
Sarcastic Mode On
"Yes, this is a long-asking wish to have a way to abort an operation without killing the process."
So why don't we have it? 😉
"I will forward your request to development for review."
According to Sean, you should have logged this issue 158 times now... 😛
Sarcastic Mode Off
Message 7 of 11
brian.cranston
I agree, we really need a cancel button. But I think the issue is broader than that. There ought to be a mechanism to avoid the model rebuild that is forced on the user. At least half the time I'm editing part features I have more than one change to make. DON'T recalc the part until I hit the lighting bolt icon- at least make the behavior toggle by some means. What a waste of time waiting for the entire part to regen and then do it again on the next feature change.
Also, there is the problem of waiting for the rebuild to finish only to find out the change I made caused that feature to fail- ARGH! Why can't Inventor tell me this right away? Add a cancel/continue msgbox for this situation
My $.02,
Brian Cranston
Message 8 of 11
Hi cranston,
If you "roll up" the End of Part marker to just below the feature you're
editing, it will delay the updates of dependent features that are below the
EoP marker. We have a defer updates mechanism for Assemblies (see
assemblies application options tab) but not for parts that I'm aware of.
I have logged wish list item 815278 "NG Customer Wish: To have defer
updates for part features" to address this.
I hope this helped...
Best regards,
Hugh Henderson (SQA Engineer)
Inventor Professional for Simulation
Message 9 of 11
JDMather
Maybe I should have wrote, "Even where there are Cancel buttons they don't respond at all in certain situations." I can find no indication that Cancel actually cancels this operation. It should be grayed out once no longer available in the command.
Message 10 of 11
I agree with Sean. I am not an expert programmer, however I know LabVIEW allows the programmer to add "Application Exit" event which is far better than "Abort Execution".
To the point, I wonder -- how easy is to add a "cancel" button?
Wendy
Message 11 of 11
I agree.
