Hi to all,
just updated to Inventor 2015
Looks like is change in NEW from QAT
in 2014 inside was:Assembly, Drawing (idw), Part & Presentation
in 2015 inside is: Assembly, Drawing (dwg), Part & Presentation
See png.
How to change it (replace command New-dwg with New-Idw
Any ideas?
Solved by karthur1. Go to Solution.
In 2015, they have set the default to *.dwg. It has always been *.idw up until now.
Tools >Application options >Drawing tab. Change the Default drawings file type from *.dwg to *.idw.
If you are using the new "My Home" screen, this will also change the type file for the drawing template.
Kirk
