How are the 5 blades created on the centre.I cannot follow the model to work it out
James
A search here should turn up many examples posted in the past.
I did a quick search and found this -
http://forums.autodesk.com/t5/Inventor-General/propeller/m-p/3727226/highlight/true#M455899
Maybe that isn't the best link
Loft surface curves.
Trim the surface.
Thicken the surface.
Fillet the solid.
Pattern the solid.
Fillet the solid to the hub.
Attach your *.ipt attempt here.
@Anonymous wrote:
This would be also a good example....would you use the Loft ?
I don't recall whether I used Coil or Loft, but it would have been one or the other.
Attach your attempt here and that would motivate me to find my example.
Are you making any progress in an attempt
What are your specifications?
Do you have a drawing that you are trying to reproduce as a model?
Do you have a physical part that you are trying to reproduce as a model?
Hi! I took a look at the original body and did a bit untrim operations (Extract Loop). The base faces creating the blades are quite simple. Please take a look atthe image and you should be able to figure out what to do next. Let me know if it works for you.
Thanks!
Hi
No drawings and no physical part.It is a learning exercise from a model i found of a propeller.
Thanks Johnson
Is there the file available for the .png you attached.Would be easier to work through and see how the steps were created
Thank you
James
