I,
Please, i need importa dwg to inventor for create a solid.
The problem is when a import the file, in the "layers and objects import options" , inventor don't show me some layers present in the dwg.
It is a problem?? or i need configurate anything???
Solved by yannick3. Go to Solution.
Something isn't right here.
Attach the dwg file here to see if others can reproduce the behavior.
I've had that happen and I THINK (I can't recall for sure) that unchecking the ALL checkbox was the trick. I may be wrong though.
desable the option "all", but the problem continue. I used drawing of the folder sample of mechanical. Attch have one sample.
Worked fine here.
What version of Inventor and AutoCAD do you have installed?
Does the problem persist after rebooting the computer?
I know I had this issue, and I tried several things, I just don't recall what worked.
Some things to try:
Hi
I think your dwg trueview installation is corrupted try to uninstall/reinstall it
no solution, but here is the same problem:
also a couple of things to try here:
including just copying the geometry in AutoCAD and Pasting into Inventor.
I reinstall dgwtrue view, bat AIP show me a error.
I attech the picture of the error!!
the problem continue... 😕
Hi
Have uninstall before
uninstall all dwg trueview release before fresh install you can download it
http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112
i've seen this issue before and the problem is dwg trueview corrupted.
I have litle bit difrent problem.
When i try import dwg files to inventor, won't show popup window with "setings" and nothing's more happen (see video on link:http://www.youtube.com/watch?v=tHyfQ8kDN7s&feature=youtu.be ). But when i try open dwg files everything works fine. Have anyone any solution for this issue?
