Inventor Forum
press
7 REPLIES 7
Message 1 of 8
698 Views, 7 Replies
press
pls see attached..
I have a metal part for which i have added a raised area which needs to be shelled out so as to replicate a dish shape.
1. Can this be shelled out and filleted so as to represent a smooth pressed raised section in the metal
I don`t know of any other way to perform this feature.
Cheers
Trent
7 REPLIES 7
Message 2 of 8
JDMather
You should use a Punch tool if you still want this to give you a Flat Pattern
otherwise
you could add the fillets and them shell (select all faces extcept the front (or back) faces.
If you were going to shell - there was an easier way to create the part.
Message 3 of 8
Hi JD
1. If you were going to shell - there was an easier way to create the part....could you please post a sample
2. How would i use the punch tool...are these already available....could you post a sample
Merry christmas
Trent
Message 4 of 8
I am interested to see an example of each,the puch tool would be the most ideal as i would still like the flat pattern feature
Cheers
Message 5 of 8
Hi JD
Any chance for a sample for each
Trent
Message 6 of 8
JD,Are you going to show your easier way to create the part?
Message 7 of 8
blair
Simply place a sketch on the face with a "Center-Mark" at the center your desired "punch" location. Then select the Punch-Tool, scroll down to the desired shape.
Please remember, unless you see "Autodesk Employee" attached to the user name, everyone else is doing this out of the goodness of their heart.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 8 of 8
in reply to: blair
Appreciated
