I wanted to choose a part that would use many of the new commands.
Surface Creation (extrude and revolve)
Surface Loft
Surface Knit
Surface Thicken
maybe replace face
etc...
all in one part
The point is not to create the part the most efficient way but to illustrate
how to use each of the commands.
I think maybe the prop would be a good 2nd lesson...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Drew Fulford" wrote in message
news:7931CBD6E37C6CFDD4A5AECD637C7FCD@in.WebX.maYIadrTaRb...
> Thicken? No need to 🙂
> Just make 2 twisted surfaces and do 2 replace faces on a chunko'material
> - drew
> Drew Fulford B.A.Sc. Systems Engineer
> Solid Caddgroup Inc. Burlington, Ontario
> Tel: (905)331-9670, Fax: (905)331-7280
> Corporate: http://www.solidcadcam.com/
> Member of the Autodesk Discussion Forum Moderator Program
> Visit my MCAD website @ http://www.mymcad.com/
> "Larry Caldwell" wrote in message
> news:61F447DA5AD54444D52D1E6B5F0E2DFD@in.WebX.maYIadrTaRb...
> > You think it would thicken? Couldn't get mine to because of the radii on
> the
> > leading and trailing edges. Ended up being a convoluted process to get
it
> to
> > work with no join lines from separate lofts.
> > ~Larry
> > news:76F87F1EBF4865F04D3315A90FDC35EC@in.WebX.maYIadrTaRb...
> > > Sean
> > > I think a propeller blade is a great example since lofting wont "cut"
> it.
> > > - Drew
> > > "Sean Dotson" wrote in message
> > > news:DDCD98DC64691069086E5F7EEBFB6E3F@in.WebX.maYIadrTaRb...
> > > > What do you want me to use as an example? I'm don't usually design
> > swoopy
> > > > shapes so I'm not sure what you guys want to see.
> > > > I played around with an example last night (See CF under Cell Phone
> > > Shell).
> > > > I didn't have my phone with me so I guessed at some dims and it was
a
> > > quick
> > > > and crude model. It wasn't too far off. In the tutorial I'd flesh
it
> > out
> > > a
> > > > bit more...
> > > > This model uses extruded and revolved surfaces, surface lofts, knit
> > > > surfaces, thicken surface, emboss, decal and standard extrude tools.
> > > > Anyway, want to see how to make this as an example? If not give me
> > > another
> > > > suggestion. I guess I'm just having writers' block.
> > > > Sean Dotson, PE
