Parametric liquid tank
- Mute
- Permalink
- Report
I'm trying to perform a parametric tank with Inventor. The problema that i have is that i dont know how to make to insert the nozzles on the tank totally parametrically: I want to have the parameter to change the flange and the pipe, and I also want to be able to adapt this pipe and flange to the Surface of the tank, and if it would be posible make the hole between them.
By now i have the main form of the tank parametric and i also have my flanges that includes the pipe, I've put there the parameter to change the DN of the flange and also there is the option, when i insert it from my Content Center, to define the diameter of the tank so the pipe on the flange adapt on it. The problema is that when i need to change the DN, on the assembly, by right button, change diameter, I lose the parameter of Tank diameter and I'am not able to change it without reincerting the flange again.
There are a better way to work on it or i should keep working on this way?
And how could i make to insert the hole on the tank automatically when I insert the flange?
