Here is what I did:
1. Changing my part in micron units.
2. in 2D sketch mode (any plane), I draw a 30-micron diameter circle.
3. Then I zoom in.
4. Panning/the hand tool (to move the view) doesn't work with the middle mouse button.
5. If I zoom out, the middle-mouse hand tool is working again at some level.
6. The hand tool in the navigation bar works fine, whatever the zooming level is.
The same problem occurs outside of the sketching mode.
Is there a way to tweak/set the middle-mouse hand tool?
It is inconvenient that I have to go to the navigation bar only to move the view slightly.
I'm sorry if I miss something/misunderstand. Thanks for the help. 🙂
Product:
Inventor Professional 2022 64-bit edition
Build: 350, release 2022.3
on windows 10
Best regards,
Tetuko
Solved by CCarreiras. Go to Solution.
Hi!
The inventor doesn't PAN at certain high-level zooming.
You have to play between zoom in/out to adjust PAN.
