Inventor Forum
Move a 3D Spline
7 REPLIES 7
Message 1 of 8
360 Views, 7 Replies
Move a 3D Spline
Does anyone know if there is a way to move a 3d spline from one point to the other?
7 REPLIES 7
Message 2 of 8
RMB on a control point and select Move/Rotate.
Message 3 of 8
Thanks for the reply! that seemed to work. Out of curiosity, does IV have a way to move the whole spline, instead of moving each control point? Like the "move" function in the 2d sketch?
Message 4 of 8
it doesn't appear to, but it would be a good addition.
Message 5 of 8
I just picked with a bounding box in the move command and was able to move
the whole spline.
wrote in message news:5993384@discussion.autodesk.com...
Message 6 of 8
Move command? I don't see one in the 3d sketch features. Where did you find the move command?
Message 7 of 8
oops, I didn't notice 3d........sorry forget I said anything....I was never
here......:)
wrote in message news:5993545@discussion.autodesk.com...
the move command?
Message 8 of 8
actually, you can select the entire spline w/ a bounding box, then move the cursor over the spline so it turns red, then LMB and hold and drag. It is kind of finicky, but if you get it just right, when you drag the cursor will change to a "drag hand" and you can drag it like Al said. No explicit Move command though.
