Inventor Forum
More sheetmetal
7 REPLIES 7
Message 1 of 8
176 Views, 7 Replies
More sheetmetal
I have been fooling around with some sheetmetal stuff. I have been trying
to make a ring with holes in it. I want to start with a flat piece, drill
the holes, and then roll it into a ring of known diameter. I have succeeded
in doing this, but not without some small defects. See CF. The holes
partially fill in when the plate is rolled.(not a biggie). I have used the
circumference to determine the length of the plate. When the plate is
rolled it overlaps - but I have the right diameter. Can anybody suggest why
I am seeing this?
Cory McConnell
BJ pipeline Inspection
7 REPLIES 7
Message 2 of 8
I would guess it has to do with the kfactor. Sheetmetal stretches when bent, and Inventor
takes that into account using either a kfactor or a bend table.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Cory McConnell" wrote in message
news:AF50711E9AD188EB431937E861EAA493@in.WebX.maYIadrTaRb...
> I am seeing this?
> Cory McConnell
Message 3 of 8
That is what I was wondering. Where does Inventor stretch the material. On
the face where the fold line is, the opposite face, or between the 2 faces,
or some arbitrary location?
Cory McConnell
"Kent Keller" wrote in message
news:E72CD79F5E939169600F92B095D0F3DA@in.WebX.maYIadrTaRb...
bent, and Inventor
> Kent
trying
drill
succeeded
the
why
> > I am seeing this?
> > Cory McConnell
Message 4 of 8
Cory:
Near as I can tell, the kFactor out from the inner surface.
For example, with the default kFactor of 0.44, the neutral axis is 44%
of the thickness out from the inner radius of the bend. Material to the
inside of this is compressed and material to the outside is stretched.
Richard
> Cory McConnell
> bent, and Inventor
>>Kent
> trying
> drill
> succeeded
> the
> why
>>>I am seeing this?
>>>Cory McConnell
Message 5 of 8
OK, that being the case, I should use the circumference of
c=PI*(id+((.44*thk)*2)). If your theory is correct, this should give me no
overlap. Is this what you are getting at?
Cory McConnell
"Richard Hinterhoeller" wrote in message
news:3DF4DD63.6000107@hfx.eastlink.ca...
> Cory:
> Richard
On
faces,
> > Cory McConnell
> > bent, and Inventor
> >>Kent
> > trying
> > drill
> > succeeded
> > the
suggest
> > why
> >>>I am seeing this?
> >>>Cory McConnell
Message 6 of 8
Cory:
Looks good.
Richard
> Cory McConnell
Message 7 of 8
Thanks - I will give it a shot, and post back a little later.
Cory McConnell
news:3DF4E065.8040205@hfx.eastlink.ca...
> Cory:
> Looks good.
> Richard
no
> > Cory McConnell
message
Message 8 of 8
That fixed it. Thanks again.
Cory McConnell
> Cory:
> Richard
On
faces,
> > Cory McConnell
> > bent, and Inventor
> >>Kent
> > trying
> > drill
> > succeeded
> > the
suggest
> > why
> >>>I am seeing this?
> >>>Cory McConnell
