Inventor Forum
Missing Face
6 REPLIES 6
1140 Views, 6 Replies
Missing Face
I am getting a Red Cross symbol for a missing face, but cannot locate it to clear it. When I open the sketch doctor for closer examination it cannot be highlighted or located and cleared.
I have opened each piece in the assembly separately and everything looks fine. (No red cross)
Any Ideas on how to clear this.
6 REPLIES 6
I found the problem by deleting a single part at the time and then undoing if the cross didnt go away. Apparently it was a constraint issue that sketch doctor couldnt identify.
Jeff,
Is this on R2008? We have seen similar issues with error complaining Missing
Edges. Could you send me the files, so I can take a look and see if the
problem has been addressed in the latest internal build?
Thanks!
Johnson Shiue
Test Engineer
(email: johnsonDOTshiueATautodeskDOTcom)
wrote in message news:5636183@discussion.autodesk.com...
I am having this problem on every assembly that I work on. There is a red cross, and the sketch doctor says "missing face", however, when the sketch doctor examines the problem it says "Could not attach to face: face could not be found." and then there is no recommended treatment for the problem. I then have to manually go through the assembly and delete components to find the source of the problem. Once found, I can then delete the component and re-insert it. Then the red cross goes away.
Here is the assembly. I moved up end of part on part 93 for smaller file size.
I just looked at this model and I have no red cross? looks ok to me no errors
After posting the file, I installed SP1 for Inventor. After the patch, the red cross no longer appears. Apparently, this was a known issue that was fixed by the patch.
Autodesk Customer Advisory Groups
