Inventor Forum
Looking for a good sheet metal nesting program.
40 REPLIES 40
Message 1 of 41
zma1013
17745 Views, 40 Replies
We use a manual shear to cut the majority of our pieces but creating a cut sheet is a time consuming process.  Does anyone know of a good sheet metal nesting program for use in efficiently placing square and rectangular shapes on sheet metal?  It doesn't necessarily have to integrate with Inventor, but that would be a nice bonus.  This is not for any kind of CNC machine, it's just for making cut sheets faster.
I've been looking at one from Striker Systems but they don't seem to have a free trial.  I requested info from them so I'm waiting on that.  Any suggestions would be appreciated.
IV2012
Windows XP SP3 32-bit
Intel Core 2 Duo 6400 @ 2.13 GHz
Nvidia Quadro FX 3450/4000 SDI 256MB Vram
2 GB Ram
160GB HDD
40 REPLIES 40
Message 2 of 41
pauldoubet
in reply to: zma1013
We use Striker software and we were able to try the products we wanted to by to make sure they would do what we expected, which was interface with Inventor and AutoCAD.
I can sum up my opinion by saying, It Works and we bought it.
Paul
Message 3 of 41
stevec781
in reply to: pauldoubet
If you dont do a lot of nesting My Netsing could be a cost effective solution.  http://www.mynesting.com/
Theres also Bobcad.
Cant comment on how good they are as I use Sigmanest.  Good software but expensive.
Message 4 of 41
Check PLUS 2D from http://www.nirvanatec.com .
Message 5 of 41
brendan.henderson
Try FastCUT from FastCAM. Only $99. We use the full FastCAM/FastNEST package for automatic nesting of odd shaped parts for our CNC plasma cutter and can recommend thier products (no kickbacks-no affiliation).
http://www.fastcamusa.com/new/fastcutmetal/
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 6 of 41
EddieGreen
in reply to: stevec781
Thanks for your suggestion about myNesting. Very useful. The same company have a standalone application called NestFab which is $1500. It seems pretty robust.
Message 7 of 41
blair
We use Radan, switching from MTC/Thermadyne. The only problem with Striker is for their sort and nest build, Inventor files need to be Sheet-Metal. If you created profiles that are not Sheet-Metal, then the auto nest build won't work and you need to manually select your items to nest.
The nest will still work but not having the ability to take a number of parts of different material and thickness and let the software soft them out and create the nested jobs.
Delta Tau Chi ΔΤΧ
Message 8 of 41
in reply to: blair
Blair,
 How is Radan working out for you? Do you have the 3d module?
Debbie
Message 9 of 41
blair
Yes,but it's not cheap. We have the 3d plugin for Inventor.
Delta Tau Chi ΔΤΧ
Message 10 of 41
in reply to: blair
IT is going to look into getting this. We have Radan but not the 3d part. We spend an insane amount of time creating flats the way the shop needs them done.
Message 11 of 41
blair
You may need to play with kFactor. I am currently at AU. Send me a private message, I have a Excel spreadsheet that helps calculate kFactor (reverse engineer) from the shot floor part. This might help adjust your kFactor.
Delta Tau Chi ΔΤΧ
Message 12 of 41
blair
in reply to: blair
Use the calculate k-Factor. Have the shop bend a predetermined length of scrape material, then get the leg measurements. This will then allow you to calculate the correct k-Factor for each machine and type of bend.
Delta Tau Chi ΔΤΧ
Message 13 of 41
in reply to: blair
Thanks, I had done that with the shop but the tables will be very helpful!
Message 14 of 41
Did you try DGNestPro from http://tangenta.hr/download
Message 15 of 41
stephengibson76
A lot depends on what you are cutting...  If its cheap material or a material you can recycle the offcuts then cheap or free nesting software will work for you depending on the shapes you are cutting effects the percentage of waste.  If you are cutting more expensive material you want to minimize waste, I have not found software that can nest parts better than me manually...  simple equation...
if "my time cost" < "waste cost saved" = do it manually
elseif "my time cost" > "waste cost saved" + "software cost" = use software
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 16 of 41
jletcher
Look into sigmanest out of all the software nest programs I have used and that is most this one worked the best.
 you click on the assembly and it extracts all flats and folded parts unfolds them reads the material and thickness and nest all with one click.
 Very Very expensive starts at $14,000.00
http://www.sigmanest.com/en-us/
 But it is great...
Message 17 of 41
sameith
in reply to: ovidiuse
We have a new Solution for the Nesting "Problem".
Our Solution has a strong optimized process in Inventor for Nesting Parts.
You can look at http://www.simplifiers.de/software/module/simple-nesting
With this solution you never have to leave Autodesk Inventor to produce nesting sheet plates.
also you can take a look here :
https://www.youtube.com/watch?v=ksMTTmy8cO8
Greetings
Steffen Sameith
Tags (1)
Message 18 of 41
vince.adams
I know this is an old post but Autodesk now offers Autodesk TruNEST (formerly from Magestic Systems). This is our own product that is integrated with Inventor & Vault and should provide Adsk CAD users their best solution for metal and composite nesting.  If you have questions, please don't hesitate to contact Taylor Munz (taylor.munz@autodesk.com) or check out the product page:
http://www.autodesk.com/products/trunest/overview
Thanks!
Vince
Message 19 of 41
FProcp
in reply to: vince.adams
Has anyone here tried
Trunest?
Franco
GMT +08:00
Message 20 of 41
vince.adams
in reply to: FProcp
Good afternoon Franc!  We would appreciate the chance to share some customer testimonials regarding TruNest success.  It is still your best solution for Inventor integrated nesting.  If you would send your contact information to my Autodesk e-mail,  I can make sure the right information is sent over.  You can reach me at vince.adams@autodesk.com.  Thanks!!
Tags (2)
