Inventor Forum
lofting smooth surface
11 REPLIES 11
Message 1 of 12
justinpcaris
319 Views, 11 Replies
i am trying to creat a boat and i am having trouble getting a smooth surface. i am getting flat surfaces and edges and i dont know why. Could anyone help me with this problem or could anyone post a boat that is smooth that i could learn from.
11 REPLIES 11
Message 2 of 12
in reply to: justinpcaris
Inventor version???????
wrote in message news:5868188@discussion.autodesk.com...
Message 3 of 12
justinpcaris
inv simulation 2008
Message 4 of 12
Most of your sketches have square or very small radius corners. Make them all the same or close to the same radius and see what the loft does. Or, make them square and loft it. You'll get a square corner obviously. Then apply a fillet to that edge.
Message 5 of 12
JDMather
I noticed that Sketch1 is not constrained, or making any use of symmetry about the origin.
There are also redundent workplanes.
I would suggest reading these documents
particularly
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
and the curvy stuff tutorials here
http://www.dimontegroup.com/Tutorials/
Message 6 of 12
You have a lot of bad profile sketches..... duplicate objects, Vertical
center lines should be construction type, No rails to guide the loft.
See attached image for ideas.....
Message 7 of 12
justinpcaris
Thanks alot for the help i guess i didnt know as much as i thought about lofting so again thanks for the help
Message 8 of 12
I don't hoard the few clues I'm privy to and am going to give you
your very first re the subject: Section curves are derived from
complex surface mathematical models, not vise versa. What you are
doing is, basically, folly. Start with something simple and work
with it until you understand what you're doing and why, go from
there.
Message 9 of 12
robmatthews
You're annoying.
Let me see...
Condescension: x5
Cryptic insults to parties unnamed: x3
Personal insult to OP: x2
Insinuation of superiority: x3
Off Topic: x0 (for a nice change...)
5+3+2+3 = 13 >5 :. DonkeyButt=Troll
(and yes I know, I have not helped the OP here.)
This is my signature, not part of my post.
Message 10 of 12
JDMather
>You're annoying....
I don't know. I thought the advice was pretty "spot on" in this case.
Message 11 of 12
> You're annoying.
Please feel free to ignore me.
I seriously doubt we share any common interests.
> DonkeyButt=Troll
Sticks and stones may break my bones but
your 'personal attacks' will never hurt me.
Message 12 of 12
-Cheers ;^)
