Yes (see attached)
I think I discuss how I add or change some of them in this paper http://home.pct.edu/~jmather/skillsusa%20university.pdf
"In the Customize dialog box, Keyboard tab, use Copy to Clipboard to copy a list of command names and their assigned aliases and shortcuts to the clipboard. You can paste this data into an Excel spreadsheet or any word processor." WikiHelp - Custom shortcut keys
I've also attached Single and Multiple key lists in a few different formats.
I like JD's short cut suggestions (see the link in his post) for sketch constraints using punctuation keys and symbols. I tried assigning different Display Modes (Shaded, Shaded with edges, Shaded with Hidden edges) to the keyboard numbers. In 2011 it works out just about right as there are about 9 display modes. This is very useful; it gives me an easy way to see things differently.
1. With Inventor as Windows active application, press the F11 key which brings up the VBA Editor then go to the File menu > Load Project... > select ShorCuts.ivb
2. Go to Inventor > Tools > Macros > select ShortCuts_ExportToExcel > Run button
cadfish -
I can't seem to get this ivb file imported into my VBA editor. I choose load project, browse to the file, pick it and choose open. Then nothing happens. When I look at my list of macro's there's no additional macros there.
Am I missing something? Using IV2012.
Thx
Hmmm. Well it won't import for me. It shows up to be loaded..... But it doesn't actually come in. There are no new macros listed after I choose "open" in the open dialog box.
Can you post a TXT file so I can create a new macro and paste it in?
Thanks for your help......
In Inventor > Tools > VBA Editor > in the VBA Editor > File > New Project > Expand UserProject1 > Expand Modules > double click on Module1 > paste in code (listed below) in window on the right > File > Save UserProject1
Sub ShortCuts_ExportToExcel() Dim oControlDefinition As ControlDefinition Dim oExcelApp As Object 'Late binding - none version specific Dim oWorkBook As Object 'Late binding - none version specific Dim oWorkSheet As Object 'Late binding - none version specific Dim lRow As Long Dim bCustomCommand As Boolean Dim bBuiltIn_IsShortcutOverridden As Boolean Dim sLastColumn As String 'Excel Constants Const xlSortOnValues As Long = 0 Const xlAscending As Long = 1 Const xlSortNormal As Long = 0 Const xlYes As Long = 1 Const xlTopToBottom As Long = 1 Const xlPinYin As Long = 1 Const xlDown As Long = -4121 Const xlFormatFromLeftOrAbove As Long = 0 Const xlPrintNoComments As Long = -4142 Const xlPortrait As Long = 1 Const xlPaperLetter As Long = 1 Const xlAutomatic As Long = -4105 Const xlDownThenOver As Long = 1 Const xlPrintErrorsDisplayed As Long = 0 Const xlEdgeBottom As Long = 9 Const xlThin As Long = 2 Const xlThick As Long = 4 Const xlMedium As Long = -4138 Const xlCenter As Long = -4108 Set oExcelApp = CreateObject("Excel.Application") oExcelApp.Visible = True Set oWorkBook = oExcelApp.ActiveWorkbook If oWorkBook Is Nothing Then Set oWorkBook = oExcelApp.Workbooks.Add Set oWorkSheet = oWorkBook.ActiveSheet oWorkSheet.Cells.NumberFormat = "@" oWorkSheet.Rows("1:3").Font.Bold = True oWorkSheet.Range("A2").Font.Color = -16776961 'Red oWorkSheet.Range("A2").Value = "Header Setup..." With oWorkSheet.Range("A1") .Value = "Inventor " & _ ThisApplication.SoftwareVersion.DisplayVersion & " Shortcuts" .Font.Size = 16 End With oWorkSheet.Range("A3").Value = "Shortcut" oWorkSheet.Columns("A").ColumnWidth = 10 oWorkSheet.Range("B3").Value = "Command Name" oWorkSheet.Columns("B").ColumnWidth = 30 oWorkSheet.Range("C3").Value = "Description" oWorkSheet.Columns("C").ColumnWidth = 60 oWorkSheet.Range("A4").Select oExcelApp.ActiveWindow.FreezePanes = True oWorkSheet.Rows("3").Borders(xlEdgeBottom).Weight = xlMedium oWorkSheet.Range("A2").Value = "Page Setup..." With oWorkSheet.PageSetup oWorkSheet.Range("A2").Value = "Page Setup: CenterHeader" .CenterHeader = Replace( _ "&""-,Bold""&20Inventor Shortcuts&""-,Regular"" &12(Page &P of &N)", _ "Inventor", "Inventor " & ThisApplication.SoftwareVersion.DisplayVersion) oWorkSheet.Range("A2").Value = "Page Setup: LeftMargin" .LeftMargin = oExcelApp.InchesToPoints(0.25) oWorkSheet.Range("A2").Value = "Page Setup: RightMargin" .RightMargin = oExcelApp.InchesToPoints(0.25) oWorkSheet.Range("A2").Value = "Page Setup: TopMargin" .TopMargin = oExcelApp.InchesToPoints(0.4) oWorkSheet.Range("A2").Value = "Page Setup: BottomMargin" .BottomMargin = oExcelApp.InchesToPoints(0.25) oWorkSheet.Range("A2").Value = "Page Setup: HeaderMargin" .HeaderMargin = oExcelApp.InchesToPoints(0#) oWorkSheet.Range("A2").Value = "Page Setup: FooterMargin" .FooterMargin = oExcelApp.InchesToPoints(0#) oWorkSheet.Range("A2").Value = "Page Setup: PrintTitleRows" .PrintTitleRows = "$3:$3" oWorkSheet.Range("A2").Value = "Page Setup: PrintGridlines" .PrintGridlines = True oWorkSheet.Range("A2").Value = "Page Setup: CenterHorizontally" .CenterHorizontally = False oWorkSheet.Range("A2").Value = "Page Setup: CenterVertically" .CenterVertically = False oWorkSheet.Range("A2").Value = "Page Setup: Orientation" .Orientation = xlPortrait oWorkSheet.Range("A2").Value = "Page Setup: PaperSize" .PaperSize = xlPaperLetter oWorkSheet.Range("A2").Value = "Page Setup: FirstPageNumber" .FirstPageNumber = xlAutomatic oWorkSheet.Range("A2").Value = "Page Setup: Order" .Order = xlDownThenOver oWorkSheet.Range("A2").Value = "Page Setup: Zoom" .Zoom = False oWorkSheet.Range("A2").Value = "Page Setup: FitToPagesWide" .FitToPagesWide = 1 oWorkSheet.Range("A2").Value = "Page Setup: FitToPagesTall" .FitToPagesTall = 100 End With sLastColumn = "C" lRow = 3 For Each oControlDefinition In ThisApplication.CommandManager.ControlDefinitions If oControlDefinition.DefaultShortcut <> "" Or _ oControlDefinition.OverrideShortcut <> "" Then lRow = lRow + 1 oWorkSheet.Range("A2").Value = "Populating Row: " & lRow If oControlDefinition.BuiltIn Then If oControlDefinition.IsShortcutOverridden Then oWorkSheet.Range("A" & lRow).Value = oControlDefinition.OverrideShortcut bBuiltIn_IsShortcutOverridden = True oWorkSheet.Range("E" & lRow).Value = oControlDefinition.DefaultShortcut Else oWorkSheet.Range("A" & lRow).Value = oControlDefinition.DefaultShortcut End If Else oWorkSheet.Rows(lRow).Font.Color = -4165632 oWorkSheet.Range("A" & lRow).Value = oControlDefinition.OverrideShortcut bCustomCommand = True oWorkSheet.Range("D" & lRow).Value = "True" End If oWorkSheet.Range("B" & lRow).Value = _ Replace(oControlDefinition.DisplayName, "&", "") oWorkSheet.Range("C" & lRow).Value = _ Replace(oControlDefinition.DescriptionText, "&", "") End If Next If bCustomCommand Or bBuiltIn_IsShortcutOverridden Then 'bBuiltIn_IsShortcutOverridden is used here to ensure there will be no column gap oWorkSheet.Range("D3").Value = "Custom Command?" sLastColumn = "D" End If If bBuiltIn_IsShortcutOverridden Then oWorkSheet.Range("E3").Value = "Default Shortcut (Overwritten)" sLastColumn = "E" End If With oWorkSheet.Range("A1:" & sLastColumn & "1") .HorizontalAlignment = xlCenter .MergeCells = True End With oWorkSheet.Range("A2").Value = "AutoFit Columns" oWorkSheet.Columns("A:" & sLastColumn).EntireColumn.AutoFit oWorkSheet.Range("A2").Value = "Sort" oWorkSheet.Sort.SortFields.Clear oWorkSheet.Sort.SortFields.Add Key:=oWorkSheet.Range("A4:A" & lRow) _ , SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal With oWorkSheet.Sort .SetRange oWorkSheet.Range("A4:" & sLastColumn & lRow) .Header = xlYes .MatchCase = False .Orientation = xlTopToBottom .SortMethod = xlPinYin .Apply End With oWorkSheet.Range("A2").Value = "PageSetup: PrintArea" oWorkSheet.PageSetup.PrintArea = "$A$4:$" & sLastColumn & "$" & lRow oWorkSheet.Range("A2").Value = "" End Sub
Hi guys, is there an update shortcut list for 2014/2015?
I am not asking for a macro because the VBA editor and Macro buttons are not functioning (...most likely disabled by the IT guys).
Thanks in advance.
