Hello all :-),
Having some trouble on the outside of this lego piece, can't for the the life of me get the desired result.
Any clues that can set me in the right direction would be greatly appreciated. Whatever I seem to do it destroys the corner radius/fillet, I can only seem to get the large radius on both sides without the corners being curved...
Images attached, using inventor 2013.
Solved by glenn-chun. Go to Solution.
I'm not 100% sure what you're looking to get ..but have draft angle might help with part of it
Something like this?
Glenn
That would be it!
I haven't yet used some of the features I can see in the browser so I will have to give that a study tomrorow.
I knew it was done by something I hadn't touched upon yet.
Thank you very much :).
I will have a few more questions in the future no doubt. Im trying to build model a small lego set.
Just finished the wheel arch now before bed :-p.
Many thanks,
Daniel
I don't have the real Lego piece 🙂 I built my model by looking at your image (Lego top example.jpg) and your model (Lego top.ipt).
Glenn
It would be very subjective if I say that's the simplest way
Some other members could post a simpler or even better way.
Glenn
Hello Glenn,
I am stuck trying to emulate the part you made. I believe you have swept that 20mm line with the radius at either end as a surface yes?
I cannot figure out how to give it a path to sweep across, is it something to do with the 3d sketch you have put in?
I have attached my second attempt.
Kind regards
Daniel
Hi Daniel,
I selected the linear edge as a path. When the sweep feature is created, Inventor automatically creates a 3D sketch from the selected edge(s). The 3D Sketch1 in your lego try 2.ipt is the correct path, but you don't have to create one manually. Just select the model edge as a sweep path, and Inventor will create a 3D sketch for you.
On another note, I used the Parallel option in sweep to ensure that the sweep surface is essentially the same as an extrusion surface. You could achieve the same result if you extrude the same open profile.
Glenn
In the .ipt I uploaded I click sweep, then select parallel and click the open profile sketch thats 5mm high.
when i go to select a path I can only select the closed profile of the top face, which then gives me an error when I try to sweep.
How did you single out the 3d sketch line only?
Kind regards
Daniel
When the closed profile is highlighted, do not left-click. Instead, do the following steps:
(1) Right-click
(2) Click Select Other...
(3) Click the down arrow, and you will see a pull-down menu appear.
(4) [Optional step] Hover the mouse over the various selections, and you will see the corresponding selection highlighted.
(5) Click a selection from the pull-down menu.
Hope this helps,
Glenn
