Inventor Forum
IV8 Constraint problems
5 REPLIES 5
pquenzi
274 Views, 5 Replies
I continue to have problems with Transitional constraints as well as constraining ball-end linkage/cylinder supported bodies (ie: aircraft simulator; six way bulldozer blade, etc)in IV8.
I've been using Inventor and MDT before it for many years so do know how to constrain things (not to say I don't make mistakes). I have removed IV7, emptied temp files, removed & reinstalled IV8 but problems persist. Parts are non adaptive and active contact solver is off.
At this point I feel it is a problem with IV8 as some of the assemblies were created in IV7 and worked fine there.
Has anyone else experienced these problems or does soemone have suggestions as to what else I might look at.
Thanks.
Phil Quenzi
5 REPLIES 5
in reply to: pquenzi
Phil,
Transitional constraints have been finnicky from
day one. They want the two parts to be close when you start.
If you would like me to look at one or more of your
assemblies, let me know.
Are you designing aircraft simulators and
bulldozers?
- Gary
pquenzi
Gary,
Bulldozers and other construction equipment, not aircraft simulators. You answered my question on transitional constraints. I guess IV8 is even more finiky than 7. I don't need to pursue that any more. I can work around it.
What is of more concern is the ball end cylinders. I would like to make a simple assembly to email to you or post on the IVCF for you to look at. Would you mind.
Phil
cylinders.
I would approach this via a point/mate
constrain.
Phil,
Post to iCF or email (or snail mail)
me.
Autodesk,
Inc
attn: Gary
Smith
7995 SW
Mohawk
Tualatin, OR
97062
class=243282219-09122003>
class=243282219-09122003>503-692-8339
Gary:
Thanks for the reply to the Phil's question about transitional constraints.
I'm currently using IV 6. I thought I was seeing some finnicky responses
when attempting to create this particular constraint. Besides being needing
to be "close" there seems to be another issue about being finnicky.
What other "requirements" are needed to sucessfully place a transitional
constraint?
Are there any "procedural" changes between IV6, IV7 or IV8?
Does it sometimes require simply attempting over and over a few times until
the constraint is solved?
Thanks for your help in this most finnicky of situations.
"Gary R Smith (Autodesk)" wrote in message
news:6482C55E436B84577F5F5FDED33EEA57@in.WebX.maYIadrTaRb...
Phil,
Transitional constraints have been finnicky from day one. They want the two
If you would like me to look at one or more of your assemblies, let me know.
Are you designing aircraft simulators and bulldozers?
- Gary
> Besides being needing to be "close"... what other "requirements"
> are needed to sucessfully place a transitional constraint?
The two parts should be in physical proximity to where they would be with
the constraint applied.
When you select the faces involved, we use the location where you have
selected the face as part of the calculation, so for example in a case where
you have a cam follower up against a cam, do not select the cylindrical face
of the follower 180 degrees away from the point where the follower comes in
contact with the face of the cam.
Other than those two guidelines, try to have at least one other constraint
placed (usually ends up being a flush) - a transitional constraint isn't
going to do well at all if it is the only contraint you have between the
moving part and the assembly.
- G
