You do not need IIS unless you want other machines to get the content from
your machine. If you install IIS after installing the Autodesk Data
Management Server (ADMS) then you need to uninstall and re-install ADMS so
the installer can detect and setup ADMS to use IIS. At this point it might
be easier to uninstall IIS, reboot and try to solve the problem at hand ...
First, startup Vault Manager. Do you have any libraries installed on the
server? If so, exit Vault Manager and go to the next step. Otherwise, you
need to install the subset of the available content libraries - they are
broken up by standard.
Next, in Inventor, log into the data management server, via "File>>Autodesk
Data Management Server" menu, is "Log In ...". Use "Administrator", no
password, and "localhost" as the server, and "Vault" as the database if you
intend to modify content. Otherwise, check the "Content Center library read
only user" button and specify "localhost" as the server. If you don't want
to deal with login anymore, be sure to check the "Automatically log in next
session" button. "The "Log In ..."button should become disabled after a
successful login.
Assuming the above went OK, check the library configuration in the project
editor ("File>>Projects", the press "Configure Content Center Libraries" on
the lower right). Do you have any libraries configured for your project? Do
they show as available? If not, did you install them? I recommend removing
any libraries from the project that were not installed.
Now, assuming your library configuration is good, try to do an "Open from
Content Center". This will take a while the first time while it caches some
data, but it should be quick afterwards.
Please post how far you are able to get and I will try to diagnose where the
problem is.
-Dave Mink
Autodesk / Data Management / Content Service
wrote in message news:5372281@discussion.autodesk.com...
Ok.....so now I figured out that the IIS was NOT installed. Is there a way
to add the AutodeskDM to the services without doing a complete reinstall of
Inventor?? I don't like having to go back through and set up all of my
preferences, shortcuts and the like. Please tell me there is a way to do
this without a complete reinstall.
