Inventor Forum
ITEM number - is it possbile to control it thru a part?
19 REPLIES 19
Message 1 of 20
447 Views, 19 Replies
I just wondered if can I assign a particular ITEM number to a particular part, instead of relying on order in the assembly.
I unsterstand I can overrite it in BOM but can I have it controlled from the part, so any time I instert it into an assembly, this particular number in ITEM coulmn pops up?
19 REPLIES 19
Message 2 of 20
mcgyvr
Nope... Of course I have NO idea why you would want that...
Message 3 of 20
in reply to: mcgyvr
Well, our manufaturing facility wants the same items being always called out with the same number.
Message 4 of 20
mcgyvr
Dumb.. Thats what part numbers are for. An item number should NOT be a controlling number.
You really need to find out why they want that and then propose a better method to solve that problem..
Frankly like I said thats what a part number is for..
I suppose you could simply use a custom field and put an item number in there and then pull that into the parts list.
But it sounds like a nightmare..
Frankly I'm very happy with the method I now use for drawings in which I don't even show a parts list on the drawing nor item numbers.. All assembly people already have a "pick list" which they pull the parts for a job.. Well I got sick of really long parts lists/item numbers,etc.. So I just ditched the parts list and simply use balloons with the part number in them instead of an item number.  Its very easy to setup in the styles to put the part number instead of item number in the balloons. No manual work is required.
Message 5 of 20
in reply to: mcgyvr
I agree with you but this is a system that is being carried over from autocad times...
Idea with a part number does not seem so bad. In my case thou, as a  value in a baloon I would have to use custom iproperty... Is that possible?
Some features are possible only for part number, like merging for example.
Message 6 of 20
In styles editor I am trying to change property display to custom iproperty but it is stuck on ITEM. How to change it?
Message 7 of 20
mcgyvr
So was wiping your butt with a leaf before toilet paper was invented.. Thank god we changed that process.
Now is the time to fix/adjust silly/dumb processes.
An item number is NOT a controlling number.
If you continue down this path ALL you are doing is making more manual work/more areas for mistakes and just plain wasting time.
A part number IS a controlling number.
People aren't totally against change (most of the time).. You simply tell them that the process of ensuring a drawings item number ONLY relates to 1 specific part number is not possible with your current software.Then propose simply using the part number instead.
Message 8 of 20
Got it, you need to have only one property displayed in the property display box.
Message 9 of 20
mcgyvr
in reply to: mcgyvr
Not to mention what method do you currently do to ensure an item number is never duplicated or taken by another part number?
If you stop using dedicated item numbers you wouldn't have to worry about that ever again either.
Message 10 of 20
in reply to: mcgyvr
Again, totally agree with you on that.
Asking for random numbers to drive an assembly, from Inventor point of vew is a nonsense.
Message 11 of 20
mcgyvr
nevermind
Message 12 of 20
jeanchile
I don't have the time to do a search of the forum right now but this has been covered before. Someone has a blog post about it so search the Autodesk Blog sites as well. The basic step is you have to create a custom iProperty that the parts list and balloons both reference. Good luck.
Inventor Professional
Message 13 of 20
in reply to: mcgyvr
"People aren't totally against change (most of the time).. You simply tell them that the process of ensuring a drawings item number ONLY relates to 1 specific part number is not possible with your current software.Then propose simply using the part number instead."
This is exacly what I did.
I work for a big organisation that is at the point of transision from Autocad to Inventor, people come up with all kinds of weird ideas.
Message 14 of 20
in reply to: jeanchile
Already figured this out.
Thanks.
Message 15 of 20
I do something what you are asking for. I have a customer that wants Part number, Code Number and Sheet number on each part.
I find it easy to do that in the top assembly Bill of materials. Open Bill pf Materials and add a Custom iProperty Column for each custom property you want. Now fill in the fields in the part row. Now you can drag your custom iproperties down to all your other parts in your BOM just like you can in Excel.
Select done and save, and all this gets saves to all yours parts. Then I need to change my parts list to show the new iproperty.
Hope this helps.
Message 16 of 20
I have all nesesery iproperties already incorporated in templates, sometimes I use BOM option as described by you.
Why would you want to have a sheet numer connected to a part?
Message 17 of 20
A General Motoring customer of ours wants it that way. It goes back to the AutoCAD days of doing things. It adds more work to output it for them.
Message 18 of 20
PaulMunford
Is this the post that you were refering to?
http://cadsetterout.com/inventor-tutorials/autodesk-inventor-creating-coordinated-bom-for-large-asse...
There are some tips about half way down the page on using bubbles to call out custom properties...
Paul
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 19 of 20
in reply to: PaulMunford
Paul,
That is how we are doing it. That's a great step by step.
Message 20 of 20
PaulMunford
Cheers Doug 🙂
Autodesk Customer Advisory Groups
