How right you are. Not sure how I missed that but thanks. Don't know either
how it got there. That's my story and I'm stickin' with it.
Thanks Many,
Jack
"Sean Dotson" wrote in message
news:6BA86D0C6033ED4ECE3C978EEB18E6E7@in.WebX.maYIadrTaRb...
> There is an extra (actually just one) embedded Spreadsheet in the original
> factory. Delete it and then you'll only have on in each child. There
> shouldn't be an embedded sheet in the factory.
> Sean Dotson, PE
> http://www.sdotson.com
> Check the Inventor FAQ for most common questions
> "Jack Brentner" wrote in message
> news:7F705A35A37DA723954794D5AA0B2CC7@in.WebX.maYIadrTaRb...
> > One last little thing. I posted a snap in CF. Why does my child show 2
> > embedded spreadsheets - Embedding1 and Embedding2? Embedding1 looks like
> the
> > spreadsheet that I started with and Embedding2 is the one with all the
> > length permutations after I added LENGTH as my #2 key. I can't seem to
> blow
> > the old one away. The funny thing is they aren't exposed in the parent
for
> > me to delete either. Is this a bug?
> > Thanks Many (again),
> > Jack
> > news:D19D1BBB45C09B45CD556F94903954FE@in.WebX.maYIadrTaRb...
> > > Send it to Charles. He's the keeper of the iparts. I just fix 'em
> > > Sean Dotson, PE
> > > ...sleep is for the weak..
> > > news:F9F26A41A9A000329D0A8C8DCF11B9BB@in.WebX.maYIadrTaRb...
> > > > Well, I'll be. That did it. Thank you, Thank you, Sean. This puppy's
> > ready
> > > > to publish. Should I send it to you or Mr. Bliss?
> > > > Thanks Many,
> > > > Jack
> > > > news:2B2B390463FD34A7CD8CA4910A2D5653@in.WebX.maYIadrTaRb...
> > > > > If you children are not being saved to a library path you can open
> the
> > > > child
> > > > > created and RMB on the plane and turn it off. If they are in a
> > library
> > > > path
> > > > > you will have to change projects or move them out of the path,
edit
> > > them,
> > > > > then move them back...
> > > > > the other (and much easier way) is View > Object Visibility > User
> > Work
> > > > > Planes. But it turns all planes in the assy off...
> > > > > Sean Dotson, PE
> > > > > news:FA27EAD2F037CF9E079267DD4B78A39F@in.WebX.maYIadrTaRb...
> > > > > > Thanks very much Sean,
> > > > > > Now it comes in and the workplane is visible. I can turn on the
> > iMate
> > > > > glyph
> > > > > > visibility and perform the mate constraint.
> > > > > > Do you know how to turn the workplane visibility off? It's like
> some
> > > > > > integral component of the ipart child now and won't go away. Not
a
> > big
> > > > > issue
> > > > > > I guess. But there's no item in the browser to right-click on.
See
> > > > > > screensnap in CF. I even went back in and made sure the
workplane
> > > > > visibility
> > > > > > was turned off in the factory, and retried the ipart in my
> fixture.
> > Is
> > > > > this
> > > > > > controlled in the table as well?
> > > > > > Thanks Many,
> > > > > > Jack
> > > > > > news:935D315EFE3D2126D473F01BD1AB15FD@in.WebX.maYIadrTaRb...
> > > > > > > Check CF under your post.
> > > > > > > You have to add the imate properties to the ipart table. It's
> the
> > > > third
> > > > > > of
> > > > > > > fourth tab on the table. When I insert it after making these
> > > changes
> > > > I
> > > > > > see
> > > > > > > the workplane and iMate glyph.
> > > > > > > Sean Dotson, PE
> > > > > > > news:F02591E3420217BC16902D477462FCC6@in.WebX.maYIadrTaRb...
> > > > > > > > I know this has already been lamented by others about
iParts,
> > but
> > > > the
> > > > > > only
> > > > > > > > one that keeps it's workplanes when "being born" is the
> default
> > > > size.
> > > > > If
> > > > > > > the
> > > > > > > > iPart author intentioned a workplane to assist in the
assembly
> > > > > > > constraining
> > > > > > > > of the child, this ability currently does not exist. The
user
> of
> > > the
> > > > > > iPart
> > > > > > > > must then construct the constraining workplane in each child
> as
> > he
> > > > > > births
> > > > > > > > them.
> > > > > > > > I understand an iMate is suggested as a workaround but I
can't
> > > seem
> > > > to
> > > > > > get
> > > > > > > > this to work off an added workplane in the factory - the
only
> > way
> > > > I've
> > > > > > > found
> > > > > > > > to properly constrain the part. Am I doing somthing wrong?
> It's
> > > that
> > > > > > pesky
> > > > > > > > drill bushing again. I'll post it again in CF. It's getting
> > close
> > > > but
> > > > > > this
> > > > > > > > issue reared it's ugly head when I went go and use the
iPart.
> > > > > > > > Thanks Many,
> > > > > > > > Jack
