So i draw a body (or assembly) and i would like to inverd what i draw ( tubing for fluid flow) to be hollow and make the hollow part solid, is there any way that i could do that??
Boundary patch the ends and Sculpt - New Solid.
Attach your file here if you can't figure it out.
Hi architect97 ,
Attached is real quick example file (created in Inventor 2015). It uses a multi-body approach, creating one body and subtracting it from another to create the void. You can use the End Of Part marker in he browser to see how this was done.
I hope this helps.
Curtis
