Solved by Mark.Lancaster. Go to Solution.
Solved by CCarreiras. Go to Solution.
Solved by mflayler2. Go to Solution.
Depends...
What industry are you going into?
Call some large firms in the area you are looking to get work in and see what they use.
But...if you learn one, the concepts of the other are easily obtained. If you learn Inventor or Creo you should be able to pick up the other on the fly or with a short learning curve by using training videos or reseller training. A lot of companies will look to your aptitude to learn instead of what you already know. Personally, I think you should look between SolidWorks and Inventor as they are the pack leaders. PTC has been too focused on their Data Management system Windchill to put the effort in Creo that they should. I will mention that a lot of gov't contracts still love PTC/Windchill as the design tool though.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
I want to have lessons for my drive license, which car should i use, a BMW or a Mercedes?
Doesn't matter, the important is that you learn to drive cars.
Same way, the important is that you learn the basic rules of CAD, 3D modeling, assembly, documenting, doesn't matter the s/w you choose. A good driver will adapt to any new car in a couple of days.
In my area, The inventor is a lot more used than Creo, so, i should pick Inventor, in your case, i don't know, it also depends the which software the employer uses, but... to learn, pick any one.
Welcome to the community...
In addition to @mflayler2 information.. Autodesk provides free software to individuals that are learning CAD products. Maybe another thing to consider when thinking about which product you want to learn..
Although new to the market and still in constant development, is Autodesk Fusion 360 which is a cloud based, next generation CAD/CAM application. Has the feel of Inventor but not the Inventor workflow aspect.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Well, you shouldn't be...you answered your own question. In your area, people use a variety of software so you should learn one and go from there. I would say learn Inventor because the interface is easy and then with that your concepts will apply to other CAD software programs as both myself and @Mark.Lancaster have mentioned.
What experience does your instructor have?
Shouldn't you involve your instructor in this discussion?
