Inventor Forum
Inventor saves the drawing to convert a bitmap view
6 REPLIES 6
703 Views, 6 Replies
The problem is this:
  1. Take a sample of "Suspensions".
  2. Autodesk Inventor in the context menu choose "Make view precise", stored, sent to the Vault
  3. make DWF, but the view is handled as a bitmap view.
Open the file in Inventor, and observe what kind of "Bitmap" for a few seconds.
Why Inventor gives save unconverted form?
6 REPLIES 6
Maxim-CADman77
I can confirm that saving drawing before all its views become precise does create situations when DWF looks pixelized.
The worst thing about it - sometimes this reulte to disappearing some lines.
May be we are missing some option that would warn those "too fast" users?
blair
in reply to: Maxim-CADman77
Application Options>Drawing: Enable background updates:
Switches the display of raster drawing views on or off.
Raster views increase your productivity when you work with drawings created for large assemblies. You can review a drawing or create drawing annotations before precise calculation of drawing views finishes. Precise drawing views are calculated in the background while you work with raster views.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Maxim-CADman77
in reply to: blair
I agree but green corners could be count kind of note only on active
sheet.
IMHO Inventor should generate warning on attempt to save drawing with at
least one precision view not precise yet.
mrattray
It does...
Mike (not Matt) Rattray
in reply to: mrattray
If enable  "Drawing: Enable background updates", Inventor allows to save the drawing without completing the calculation end... There is no "warning".
mrattray
Interesting... IV used to warn you if you had views that were still in raster. I wonder if this is a regression, or a foolish change.
