Inventor Forum
Inventor crashing on startup
7 REPLIES 7
Message 1 of 8
3078 Views, 7 Replies
What does this mean? Inventor 2009 crashes when I try to launch.
Problem Event Name: APPCRASH
Application Name: Inventor.exe
Application Version: 13.2.0.29800
Application Timestamp: 49d50fd7
Fault Module Name: mscorwks.dll
Fault Module Version: 2.0.50727.4200
Fault Module Timestamp: 4a9ee32d
Exception Code: c0000005
Exception Offset: 00000000006cf399
OS Version: 6.0.6002.2.2.0.256.1
Locale ID: 1033
Daryl
7 REPLIES 7
Message 2 of 8
Dear Daryl,
Could you please provide more information? Are there any reproducible steps?
Whether do you install any service pack or hotfix? Please send out the CER
report if you can replay the crash and CER dialog pops up.
Marshal
wrote in message
news:6303259@discussion.autodesk.com...
Locale ID: 1033
Daryl
Message 3 of 8
From the information you provide, I would reinstall .net framework.
Again, more information is needed...
http://teknigroup.com/support/Inventor/Howto.html
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
Message 4 of 8
Beschrijving:
Stopped working
Probleemhandtekening:
Gebeurtenisnaam van probleem: APPCRASH
Application Version: 13.0.0.23600
Application Timestamp: 47be19c6
Fault Module Version: 2.0.50727.4927
Fault Module Timestamp: 4a27466f
Exception Offset: 00000000006ca939
Versie van besturingssysteem: 6.1.7600.2.0.0.768.3
Landinstelling-id: 1043
same here..
looks like a time out ?
removed framework 3.5.1
removed update for framework 1. / 2
removed autocad inventor
(incl. filles in register and user )
used ccleaner for ensurance.
reinstall inventor 2009 pro.
reinstall framwork..
same error ! Edited by: do0fusz on Dec 30, 2009 6:31 PM
Message 5 of 8
If memory serves me, error c0000005 is an access violation most commonly due to buffer overrun?
Message 6 of 8
Same problem here, Does anyone have a fix,
is it framework, buffer overrun or something else, I tried Just delete (move, or rename just in case) C:\Users\YourUserHere\AppData\Roaming\Autodesk\Autodesk Inventor 2009 folder and it should work correctly.......after 2 weeks, got same thing.
I'm running ASUS laptop, intel 2.1 dual core, 4gig ram, 500gig hd, nvidia geforce g102m cuda 512mb graphics card
Any assistance would be greatly appreciated.
Regards!
Sylvain
Message 7 of 8
helmut.backs
Hi Sylvain,
could it be a graphics card problem? Please try to slow down the hardware acceleration. Because I´m a WindowsXP-user I only can describe it this way: Go to the display properties, click "Advanced", choose the "Troubleshoot" tab and change "Hardware acceleration" from "Full" to "None".
Helmut
Message 8 of 8
Is this what you mean?
right now, it is set for graphics. I have 3 settings:
1- Performance
2-Balance
3-Graphics
by the way, I'm using windows7 home premium.
Could it be a windows7 problem?
windows7 is supposed to be 1 step up from vista, but maybe not supported by inventor?.............but I think others are having the same problem while running vista.
P.S. I just re-installed inventor with new activation code, changed the name of above said file and it's running fine(for now) but have no idea for how long.
Thanks again, Helmut
