Hi!
I can´t find info about this:
would somebody tell us the difference between the Nesting Templates?
@CCarreiras,
marius.gildehaus has edited your subject line for clarity
Original: Difference between Nesting Utility Templates
Solved by johnsonshiue. Go to Solution.
Solved by AmyLiu. Go to Solution.
@CCarreiras thanks for your attention.
the list of templates are a slight difference, mainly on unit.
you can see unit difference easily from the template file name.
plus, template file without unit is using application default unit; and Norm is for DEU template specified.
hope it helps.
thanks,
Amy
Hi Carlos,
DEU stands for "Deutsche", German.
Many thanks!
Hello @CCarreiras!
Please hit the Accept as Solution button if the posts from @johnsonshiue and @AmyLiu answer your question.
Thanks!
