Inventor Forum
Inventor 2014 will not download - missing files
9 REPLIES 9
Message 1 of 10
2695 Views, 9 Replies
Try as I might I can not get Inventor 2014 to down load using either the downloaded routine or the browser download
I've tried with firewall off, on a different machine, with IE11 and goggle chrome
9 REPLIES 9
Message 2 of 10
cieslak.maciek
To be honest, that is strange, because I have no problems whatsoever to start downloading the file. You can reach out for help directly to the support staff.
https://autodesk.zendesk.com/anonymous_requests/new
Message 3 of 10
blair
in reply to: cieslak.maciek
Is this from the Student Download or from the commercial side, either the Subscription or Free Trial download? All all the same product, all that changes is your Product Key and Reg Number.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 10
jeffrey.sin
Hi Paul,
If you were downloading Autodesk Inventor 2014 for Windows 64-bit, there are 2 parts to the installation files. You may try to download and save the installation files using the links below, make sure to save both files/parts onto the same folder.
Autodesk Inventor 2014 for Windows 64-bit Part 1
Autodesk Inventor 2014 for Windows 64-bit Part 2
Let us know if this works out for you.
Jeffrey Sin
Autodesk Customer Support
Message 5 of 10
cieslak.maciek
in reply to: blair
The product keys don't change. All are the same. Only serial number changes.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/2014-Pr...
Message 6 of 10
Firstly folks thanks for the replies
To answer the questions originally it was the Educational version that I was trying to download from, that kept failing so I tried the free trial with the same results. I at fist thought it was a problem with IE11 but had the same problems with Google.
However thanks to jeffrey.sin (Product Support) for the two links the files have now downloaded.
Message 7 of 10
blair
Product Key will determine the flavor of Inventor, basic Inventor or Inventor Pro...
Delta Tau Chi ΔΤΧ
Message 8 of 10
cieslak.maciek
in reply to: blair
They don't change in between Student, NFR, Commercial versions. That's what I meant.
Message 9 of 10
in reply to: jeffrey.sin
Hi Jeffrey,
I have the same problem as Paul, but with 'Autodesk Inventor Professional 2014 - WIN 64 - EN'
I've downloaded using 'Browser Download' option, but when I run the exe, it says there is a missing part.
Could you please send a link for the 'Inventor Professional' file parts too?
Thanks!
Laszlo Meszena
Message 10 of 10
