Try as I might I can not get Inventor 2014 to down load using either the downloaded routine or the browser download
I've tried with firewall off, on a different machine, with IE11 and goggle chrome
Solved by jeffrey.sin. Go to Solution.
Is this from the Student Download or from the commercial side, either the Subscription or Free Trial download? All all the same product, all that changes is your Product Key and Reg Number.
Hi Paul,
If you were downloading Autodesk Inventor 2014 for Windows 64-bit, there are 2 parts to the installation files. You may try to download and save the installation files using the links below, make sure to save both files/parts onto the same folder.
Autodesk Inventor 2014 for Windows 64-bit Part 1
Autodesk Inventor 2014 for Windows 64-bit Part 2
Let us know if this works out for you.
Firstly folks thanks for the replies
To answer the questions originally it was the Educational version that I was trying to download from, that kept failing so I tried the free trial with the same results. I at fist thought it was a problem with IE11 but had the same problems with Google.
However thanks to jeffrey.sin (Product Support) for the two links the files have now downloaded.
Hi Jeffrey,
I have the same problem as Paul, but with 'Autodesk Inventor Professional 2014 - WIN 64 - EN'
I've downloaded using 'Browser Download' option, but when I run the exe, it says there is a missing part.
Could you please send a link for the 'Inventor Professional' file parts too?
Thanks!
Laszlo Meszena
Hi guys,
I've find the anwear:
Sorry for the double!
Laszlo
