Inventor Forum
Inventor 2014 dwg export 1:1 - essentials
5 REPLIES 5
1240 Views, 5 Replies
anyone knows if there is some bug in 2014 while exporting to dwg?...
I haven't this kind of problem (described below) in previous versions...
I have idw, e.g. 1:2 and I want to export it to dwg but with 1:1 scale including title block - there is no such an option to make it right. Scale is still wrong.
Only possible way deletes automatically title block.
Other way is to have idw drawing in 1:1 scale but sometimes it is not possible (to small paper sheet).
I checked all export options. No success.
MB
Tags (3)
5 REPLIES 5
JoAnn_Hogan
Hi MB,
Do you have all the relevant service packs installed for Inventor 2014? Including update 3?
Has it always been doing this in your Inventor 2014 or just lately?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
in reply to: JoAnn_Hogan
sorry, it didn't help
JoAnn_Hogan
Jo - Ann
well, it was my first exports to dwg in this inventor version
of course i did earlier in older versions
karthur1
MB,
When you export to .dwg, which data scale option are you using?  If you want the dwg to be 1:1, then use the "Base View Scale - Model Space" option.  Note that using this option, it scales the drawing based on the FIRST view placed in the idw. So, if there are other views in the idw that are a different scale than the first base view, they may not be correct scale in the dwg.
Kirk
