Inventor Forum
Inventor 2013 .dwg dimensions
2 REPLIES 2
cparnell
272 Views, 2 Replies
When I use Autocad if the dimension extension lines are too close I could cause the dimension to be placed on the  left or right side as desired. If I selected what I wanted to dimension starting left to right the dimension would be placed on the right side of the extension lines and vice versa going the other way. Is there a way to cause Inventor to do this? I seems like no matter what direction I chose, the dimenion ends up where I don't want it. Typically liner fraction dimenison.
This has bugged me for several releases now. Thanks for any help.
2 REPLIES 2
Curtis:
Yes that did it. Thank you very much for the help and your link.
