Inventor Forum
Inventor 2013 can't save as Cad format
8 REPLIES 8
Message 1 of 9
mohandis2
1885 Views, 8 Replies
Autodesk Inventor 2013 does not save as Autocad format either using save as or export command, see the attached picture for Inventor message
Does any one know why?
8 REPLIES 8
Message 2 of 9
bob_holland
in reply to: mohandis2
Said,
Can you tell us if this happens on all of your parts?
Does this happen to others in your organization?
What location are you trying to save this file to?
What OS is on your computer?
Please send us an update when you have an opportunity.
Thank you.
Bob Holland
Autodesk Product Support
Message 3 of 9
mohandis2
in reply to: bob_holland
Yes, it happen with all the parts
I'm the only one using inventor
I'm trying to save the cad in the folder where the part is saved
The OS is windows 7
By the way, it happen with all these ways:
Save as copy
Export-cad format
Export-Export dwg
The "Option..." button in the save dialogue box is clickable, but nothing pops up
Thanks for your replay
Message 4 of 9
bob_holland
Said,
Please check the status of your Translator Addins.
You should have one for DWG.
Thank you.
Bob Holland
Message 5 of 9
mohandis2
Well, I found one, it's status was "Automatic/On Demand" witch I changed to "Automatic/Loaded" and clicked OK
however the problem was not solved, when open the same AddIn dialogue box, it's state change back to "Automatic/On Demand"
witch means it did not load.
please see attachment
Message 6 of 9
johnsonshiue
Hi! Based on the snapshot you captured at the beginning of the thread, it seems like you were doing Save Copy As of Flat Pattern in Sheet Metal. Could you simply right-click any flat part face -> Export Face As. Does it work? If not, could you take a look at the following workaround and see if it helps?
http://forums.autodesk.com/t5/Inventor-General/Inventor-2014-fails-to-export-to-DWG-on-Win-8-1/td-p/...
Thanks!
Software Test Engineer
Message 7 of 9
pcrawley
in reply to: johnsonshiue
I've had a very similar problem and discovered it was caused by a failed instance of DWG TrueView.
Try reinstalling DWG TrueView and launch it once using the "Run As Administrator" option as suggested in the previous post.
Then re-try the various export options.
Peter
Message 8 of 9
LT.Rusty
We had this exact issue pop up today - unable to export .DWG, Inventor 2013 w/all updates, Windows 7 - and what is described in the link that Johnson recommended worked.  No idea why it cropped up.  We haven't had any changes to hardware or software, so there's no real reason for anything to change with Inventor.
Rusty
Message 9 of 9
mohandis2
Thanks, that link solved my problem
