Inventor Forum
Inserting sketched symbols to a center point
8 REPLIES 8
Message 1 of 9
180 Views, 8 Replies
When inserting a sketched symbol, is it possible to snap to the center point of a circle? I have not been able to do it.
8 REPLIES 8
Message 2 of 9
Place a sketch on the view. Project the target circle in question, next pick
the centerpoint and change it's style from "reference" to "Connection
point". Exit sketch. Use Symbols command with "leader" unchecked to place
sketched symbol that will stay attached to that point.
PS. After placement, dont drag it off or you'll never get it back on without
re-inserting it!
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Toll Free: 1-(866) 698-2831, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"tsweeney" wrote in message
news:f169170.-1@WebX.maYIadrTaRb...
Message 3 of 9
I've tried this. The problem is not the symbol, but the circle itself. When
inserting, it will not allow a snap to center. This was one of my gripes awhile
back.
Dave Jacquemotte
Automation Designer
Message 4 of 9
Holy Mackeral!
2 posts in as many days.
Are we seeing a trend developing?
QBZ
"Drew Fulford" wrote in message
news:7C9ED973C33F2D17933B490A308826AA@in.WebX.maYIadrTaRb...
pick
without
> re-inserting it!
Message 5 of 9
After re-re-reading your answer, I now realize this is NOT what I was doing.
However, your solution is not a viable workaround when you are inserting 10
dowel symbols.
Dave Jacquemotte
Automation Designer
Message 6 of 9
Dave
All 10 circular projections and point style edits can be in the same sketch
to quicken things up. I agree its a PITA but it's more viable than a non
centered dowel symbol.
- drew
"Dave J" wrote in message
news:3321F9B23B520365BE43BF726B468870@in.WebX.maYIadrTaRb...
doing.
10
> dowel symbols.
> Dave Jacquemotte
> Automation Designer
Message 7 of 9
shhh....
"Quinn Zander" wrote in message
news:2EA20FC9369F1385AAF360E30B0EB29E@in.WebX.maYIadrTaRb...
> Holy Mackeral!
> QBZ
> pick
place
> without
> > re-inserting it!
Message 8 of 9
Well, Drew. I've tried your method now and I still can not get the
connection/insert point (I've tried both) of the symbol to connect to the
Connection Point of the sketch. it shows up as I'm placing, but will not snap to
it.
As it is, I will continue to Auto Centerline and snap to that.
Dave Jacquemotte
Automation Designer
Message 9 of 9
I finally got that to work with the connection point mehtod. But I think I am going to stick with the way I was doing it in 5.3. You make the sketch on the view, project the dowel hole circle, draw a line from the center to each four quadrants, then fill two of the quadrants with a hatch pattern. What threw me in R7 was that in order for the circle to project, you have to have "autoproject edges during curve creation" checked in the application options.
