I'm trying to import a Catia file into inventor. I have no experience with Catia.
It will only import with one surface. I am selecting individual surfaces on the import option screen. Also, one body needs to be repaired. I'm not sure how to do this. I have tried to to heal the surfaces and change my allowance to .25mm. I had no luck.
I also have the same in an stp file. However, similar problems exist. I have attached the catia file and my part file after import and some attempted healing.
When I look at the report this what I see
At this point I think the CATIA or STEP file is bad and you should request a new one.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Walter must be sleeping.
Try the attached file. (stitched to solid but did not fix the surface with issue)
Can you request a Parasolid *.X_b file from the source?
As far as I know it is a native Catia file.
Is parasolids the best to resquest?
