I cannot figure out why part COM53100 in the attached step file comes in as transparent. Is it a solid body? It seems every STEP model from this manufacturer imports with the same transparent face on the front door.
If I change the iproperties of the part and set it to a color, I can make it opaque, but it no longer matches the rest of the model.
Thank you!
Solved by kacper.suchomski. Go to Solution.
Hi
Yes, this part is set to transparent. The manufacturer probably wanted to present the interior of the product in this way.
Open the part and remove the color override.
Kacper Suchomski
I cannot locate where it is set to transparent. Can you tell me where to find it?
Just open the part and use the color override remover.
Kacper Suchomski
