Is there a way to turn off visibility on work planes using ilogic? Also, is there a way to change an extrusion type from an assymetrical extrusion to a one direction extrusion using ilogic?
Solved by caroline.ccc. Go to Solution.
Solved by Curtis_Waguespack. Go to Solution.
Hi Curtis,
I came across your comprehensive reply and wondered if you could help me with a simpler problem please?
I have an assembly made up of identical sub assembles which in turn deploy identical parts. Thus I want to be able to turn off all work planes and just select a particular workplane in a particular sub-assembly to switch on and then off when I have finished with it. Otherwise my model is obscured often by hundreds of identical workplanes. At the moment I am having to select them individually in the Browser.
Thus I want a message box that allows me to turn on the workplane which I have physically selected in my browser. So that after selecting a particular work plane I could then choose either the 'Visible' or 'Invisible' Button in my message Box.
I am not sure if you will receive this message but if you do and you can help I would be most and I do mean MOST grateful.
Thank you.
CJ
Curtis_Waguespack написано:Hi rjones0215,
Here's another rule that toggles all of the workplanes on/off.
I hope this helps.
Curtis
'define document Dim oDoc As PartDocument oDoc = ThisDoc.Document 'look at the workplane collection For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes 'toggle all work planes If oWorkPlane.Visible = True Then oWorkPlane.Visible = False ElseIf oWorkPlane.Visible = False Then oWorkPlane.Visible = True End If Next
If you want to turn on the visibility of a specified component?
ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select component")
Hi Niksasa,
I am most grateful but can you help further please with this error message:
Error in rule: WorkPlanes, in document: ???.iam
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
As I am in the top level Assembly with sub assemblies within sub assemblies and I too would like to be able to control all work features; would I be better using Curtis' alternative proposal of:
'get user input
oInput = InputRadioBox("Select work feature visibility:", _
"Turn ON work features for all components", _
"Turn OFF work features for all components", "False", "iLogic")
' set a reference to the assembly component definintion.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Define the open document (top level assembly)
Dim openDoc As Document
openDoc = ThisDoc.Document
'define view rep
Dim oViewRep As DesignViewRepresentation
Dim sVRep as String
'change to something else if Default is used for something already
sVRep = "Default"
'create or activate view rep in the top level assembly
Try
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate
Catch
'create new View Rep
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(sVRep)
End Try
'create or activate view rep in subassemblies
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
Dim subDoc As AssemblyComponentDefinition
If docFile.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
subDoc = docFile.ComponentDefinition
Try
subDoc.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate
Catch
subDoc.RepresentationsManager.DesignViewRepresentations.Add(sVRep)
End Try
Else
End If
Next
'toggle work features in the open document (top level assembly)
For Each oWorkPlane In openDoc.ComponentDefinition.WorkPlanes
If oInput = True Then
ElseIf oInput = False Then
End If
Next
For Each oWorkAxis In openDoc.ComponentDefinition.WorkAxes
oWorkAxis.Visible = True
oWorkAxis.Visible = False
End If
Next
For Each oWorkPoint In openDoc.ComponentDefinition.WorkPoints
oWorkPoint.Visible = True
oWorkPoint.Visible = False
End If
Next
'look at only the subassemblies
Dim subDocFile As Document
For each oCompOcc in oAsmCompDef.Occurrences
If oCompOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
oCompOcc.SetDesignViewRepresentation(sVRep,, True) 'True sets the view rep to be associative
Else
End If
Next
'Look at all of the files referenced in the open document
'toggle work features in the components
For Each oWorkPlane In docFile.ComponentDefinition.WorkPlanes
End If
Next
For Each oWorkAxis In docFile.ComponentDefinition.WorkAxes
End If
Next
For Each oWorkPoint In docFile.ComponentDefinition.WorkPoints
End If
Next
Next
iLogicVb.UpdateWhenDone = True
Although this returns the error of:
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Can you help further please?
Many, many thanks,
CJ
CJ.10E-10mm написано:Hi Niksasa,
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).Although this returns the error of:
Many, many thanks,
CJ
Hi CJ. I'm new to ilogic. So do not know if I can help
PS: sorry for bad english
I'm playing around with sample #4 - cause I often find myself opening old assemblies and being confronted with a million (at least) work planes, axis' odd stuff (see attachment) - and having to turn the visibility off manually - is time consuming.
I know you can hide the work features easilly with "Object Visibility" - but I want to turn the visibility off completely as part of our cleanup routine.
I get the following error though - when using sample #4 iLogic
Error in rule: WP, in document: 810.50.001.IAM Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
System.Runtime.InteropServices.COMException (0x80020003): Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND)) at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack) at LmiRuleScript.Main() at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem) at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Edited: Should clarify - it's the modified version of sample #4 - that handles all work features - not just work planes
Added extra error code information
Any thoughts?
A small addition to make also sketches invisible.
Thanks for the source !!
For Each oSketches In openDoc.ComponentDefinition.Sketches If oInput = True Then oSketches.Visible = True ElseIf oInput = False Then oSketches.Visible = False End If Next
and
For Each oSketches In docFile.ComponentDefinition.Sketches If oInput = True Then oSketches.Visible = True ElseIf oInput = False Then oSketches.Visible = False End If Next
'get user input oInput = InputRadioBox("Select work feature visibility:", _ "Turn ON work features for all components", _ "Turn OFF work features for all components", "False", "iLogic") ' set a reference to the assembly component definintion. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'Define the open document (top level assembly) Dim openDoc As Document openDoc = ThisDoc.Document 'define view rep Dim oViewRep As DesignViewRepresentation Dim sVRep As String 'change to something else if Default is used for something already sVRep = "Default" 'create or activate view rep in the top level assembly Try oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate Catch 'create new View Rep oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(sVRep) End Try 'create or activate view rep in subassemblies Dim docFile As Document For Each docFile In openDoc.AllReferencedDocuments Dim subDoc As AssemblyComponentDefinition If docFile.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then subDoc = docFile.ComponentDefinition Try subDoc.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate Catch 'create new View Rep subDoc.RepresentationsManager.DesignViewRepresentations.Add(sVRep) End Try Else End If Next 'toggle work features in the open document (top level assembly) For Each oWorkPlane In openDoc.ComponentDefinition.WorkPlanes If oInput = True Then oWorkPlane.Visible = True ElseIf oInput = False Then oWorkPlane.Visible = False End If Next For Each oWorkAxis In openDoc.ComponentDefinition.WorkAxes If oInput = True Then oWorkAxis.Visible = True ElseIf oInput = False Then oWorkAxis.Visible = False End If Next For Each oWorkPoint In openDoc.ComponentDefinition.WorkPoints If oInput = True Then oWorkPoint.Visible = True ElseIf oInput = False Then oWorkPoint.Visible = False End If Next For Each oSketches In openDoc.ComponentDefinition.Sketches If oInput = True Then oSketches.Visible = True ElseIf oInput = False Then oSketches.Visible = False End If Next 'look at only the subassemblies Dim subDocFile As Document For Each oCompOcc in oAsmCompDef.Occurrences If oCompOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oCompOcc.SetDesignViewRepresentation(sVRep,, True) 'True sets the view rep to be associative Else End If Next 'Look at all of the files referenced in the open document For Each docFile In openDoc.AllReferencedDocuments 'toggle work features in the components For Each oWorkPlane In docFile.ComponentDefinition.WorkPlanes If oInput = True Then oWorkPlane.Visible = True ElseIf oInput = False Then oWorkPlane.Visible = False End If Next For Each oWorkAxis In docFile.ComponentDefinition.WorkAxes If oInput = True Then oWorkAxis.Visible = True ElseIf oInput = False Then oWorkAxis.Visible = False End If Next For Each oWorkPoint In docFile.ComponentDefinition.WorkPoints If oInput = True Then oWorkPoint.Visible = True ElseIf oInput = False Then oWorkPoint.Visible = False End If Next For Each oSketches In docFile.ComponentDefinition.Sketches If oInput = True Then oSketches.Visible = True ElseIf oInput = False Then oSketches.Visible = False End If Next Next iLogicVb.UpdateWhenDone = True
Hi Curtis,
I'm looking to do something similar, but maybe simpler. I have this assembly with parts in it. I want to be able to toggle the visibility of workplanes in specific components. Not all of them at the same time. Is it possible?
'catch and skip errors
On Error Resume Next
'define the active assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'get user input as True or False
wfBoolean = InputRadioBox("Turn all Work Features On/Off", "On", "Off", False, "iLogic")
'Check all referenced docs
Dim oDoc As Inventor.Document
For Each oDoc In oAssyDoc.AllReferencedDocuments
'set work plane visibility
oWorkPlane.Visible = wfBoolean
Next
'set work axis visibility
For Each oWorkAxis In oDoc.ComponentDefinition.WorkAxes
oWorkAxis.Visible = wfBoolean
Next
'set work point visibility
For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints
oWorkPoint.Visible = wfBoolean
Next
'set sketch visibility
For Each oSketch In oDoc.ComponentDefinition.Sketches
oSketch.Visible = wfBoolean
Next
Next
'update the files
InventorVb.DocumentUpdate()
I found this snippet online (that I think you may have wrote?) Anyway, I tried using as is, didn't work. I tried modifying it to fit my needs, didn't work either.
Can use this to turn off all work features.
ThisDoc.Document.ObjectVisibility.AllWorkFeatures = False
