Inventor Forum
ilogic - Adding User Parameters with Custom Properties Format
16 REPLIES 16
Message 1 of 17
brian
6283 Views, 16 Replies
I would like to have a rule that will add specific user parameters to a part file.  These parameters need to be formatted so the width, depth and thickness will control the description of the part.
IE:
Width=4
Depth=2
Thickness=3/16
DESCRIPTION = TS <Width>X<Depth>X<Thickness>
I would like to format each parameter so that the:
Format=Fractional
Precision=1/16
Unit string=False
This is what I have so far:
 oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter=oMyParameter.AddByExpression("Width", "TOP_RAIL_WIDTH", UnitsTypeEnum.kInchLengthUnits)
oParameter.ExposedAsProperty=True
oParameter.Units="in"
oParameter=oMyParameter.AddByExpression("Depth", "TOP_RAIL_DEPTH", UnitsTypeEnum.kInchLengthUnits)
oParameter=oMyParameter.AddByExpression("Thickness", "TOP_RAIL_THICKNESS", UnitsTypeEnum.kInchLengthUnits)
The TOP_RAIL parameters are from a linked file.
Brian
16 REPLIES 16
Message 2 of 17
jletcher
in reply to: brian
just put a check in the export box in the parameters. for the format after you put a check mark in the export box if you go over to the equation right click you wil have new options. One is custom property format in there you can change the output.....
Message 3 of 17
jletcher
in reply to: jletcher
Oh and you don't really need ilogic..
Message 4 of 17
Curtis_Waguespack
in reply to: brian
Hi brian
Here is some iLogic code and an example file that will format parameters and add them to the Description iProperty.
I hope this helps.
Curtis
Dim oWidth, oDepth, oThickness  As Parameter
Dim oFormat As CustomPropertyFormat
oWidth = Parameter.Param("Width")
oWidth.ExposedAsProperty = True
oFormat=oWidth.CustomPropertyFormat
oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
oFormat.Units="in"
oFormat.ShowUnitsString=False
oDepth = Parameter.Param("Depth")
oDepth.ExposedAsProperty = True
oFormat=oDepth.CustomPropertyFormat
oFormat.Units="in"
oThickness = Parameter.Param("Thickness")
oThickness.ExposedAsProperty = True
oFormat=oThickness.CustomPropertyFormat
oFormat.Units="in"
iProperties.Value("Project", "Description") = "= TS <Width> x <Depth> x <Thickness>"
Message 5 of 17
brian
in reply to: Curtis_Waguespack
Curtis,
It works great.
Brian
Message 6 of 17
Curtis_Waguespack
in reply to: brian
Hi brian,
I'm glad to hear that worked.
I noticed that I left those first two lines of the code in. They're not really needed, and don't really do anything as written because  those things get defined later in the code. They were just vestiges of my first attempt that I forgot to remove once I went a different way.  I just thought I'd mention it in case it confuses someone who happens upon this in the future.
I hope this helps.
Curtis
so, this works just as well:
oFormat.Units="in"
oFormat.Units="in"
oFormat.Units="in"
Message 7 of 17
in reply to: brian
sir can anyone help me to update the thickness of a sheet metal,  through custom properties in BOM(Assembly level)
if i create opposite hand of a part the thickness will not getting updated please help me out update through custom properties, i want like if i update the custom properties thickness then automatically it has to get updated in parameters.
thanks and regards
Manjunatha
Message 8 of 17
sir, can you help me create co to remove All Custom property?
i want to clearup all custom properties and add new one.
Thanks and regard
Message 9 of 17
Remove directly from iproperties.
Message 10 of 17
Create the opposite hand using derived component. Derive a mirror part and bring the parameters of the original. This way both thicknesses will get updated.
Message 11 of 17
in reply to: brian
it's possible to add a allow customvalues in the end of multivalue list???
oInsulationType=oUserParams.AddByValue("CHANTS", "AUCUN", kTextUnits)
MultiValue.SetList("CHANTS", "AUCUN", "1C", "1L", "1L-1C", "1L-2C", "2L", "2L-1C", "2L-2C")
Thanks for your help!
Message 12 of 17
Hi Curtis,
Sorry to be a bother but my Inventor doesn't like that code.  I put the rule in and then try to OK it but it comes up with an error.  I've attached a screenshot of the error.
If it's not too much hassle could you tell me what the problem may be?  All I did was copy and paste your code.
Message 13 of 17
I have sorted it! It just took some logical effort and deciphering what the code means at each stage.
Message 14 of 17
Can I get that code
Message 15 of 17
What exactly do you need?  Mine is just a metric version of what Curtis has already posted earlier.
Message 16 of 17
OK
Know I will explain you clearly.
If I update anything In custom it has to get updated in parameters.
Know its reverse is happening, I want custom to parameters.
Example,
If the value of sheet thickness is 10 that I want to change through
assembly bom, I can call the custom I property in assembly bom there i Can
directly change directly.
So please give any soln.
Message 17 of 17
I too am trying to use iLogic to create a multivalue parameter and also make it allow custom values.  So far I am stumped.
