True, but a cancel button would just abandon the process regardless of the
state it was in...
Sub Cancel.Click()
Cancel, End, Stop, Halt, Quit, etc.../
End Sub
(I just love making up programming syntax
The ESC button doesn't always work....
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Albert Allen" wrote in message
news:11CE4FE2461CF068B2D092FEC50E030E@in.WebX.maYIadrTaRb...
> We were just talking about that here and came to the conclusion that if
> there was a way for Inventor to give you a warning that it could not do
the
> operation then that utility itself would meet the same fate. Catch 22,
> situation pthhhh
> "Sean Dotson" wrote in message
> news:982CEF722C55821EED6E843066CC014C@in.WebX.maYIadrTaRb...
> > For those times when you are sitting waiting for the loft, sweep or
> pattern
> > to generate then you realize "This just ain't gonna happen..."
> > Currently the cancel button is "Alt-Ctrl-Del" then kill the Inventor.exe
> > process...
> > I'd love to see a bit more elegant solution...
> > Sean Dotson, PE
