Inventor Forum
How to remove a piece from object in Inventor 2013
5 REPLIES 5
3077 Views, 5 Replies
I'm currently learning Inventor, but I haven't seen this function covered in a tutorial: I need to remove a piece from my part that is an odd shape. In my case, it's an inverted pyramid. I don't think there is a way to extrude it and cut, but is there a way to sketch the shape and have the bottom point constrained to my object's center? So far I can sketch on the top face, but can't connect lines to a point not on that same surface.
Any suggestions as to the best method are very much appreciated!
5 REPLIES 5
Have you discovered the extrude functions taper parameter yet?
Or you could also make the pyramid as a part on it's own, then derive it into your part and perform a boolean type cut operation.
Hi CAG_DRAFT,
Thanks for the tip! I was excited to see the flyout menu for the Extrude function. I have created my sketch on the top face of my part, but it won't let me do any extrusion, so I haven't gotten to play with the taper tool yet. I suspect a constraint problem. I was encouraged to see that your starting shape was the same light green color as mine. Do you know what I need to change to free the finished sketch on the face?
Here's how mine looks:
CCarreiras
Hi!
You have a multi solid, so you have to chose the profile and also the solid.
If you can´t chose a profile, probably it's because it isnt closed, so edit the sketch and close it.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
JDMather
You also have the outside edges projected - so you have two closed profiles.  Which one do you want (you have to tell Inventor).
I recommend you go through these
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
and attach *.ipt files here when you run into trouble.
in reply to: JDMather
Thank you all for the advice. JD, I have downloaded your 60 Inventor Tips, and will refer to it as I learn. I have the tutorial course taught by John Helfen, and this first project has made me realize that I need to go back into it and complete some of the exercises, which I am now doing. I wasn't clear on open and closed profiles, and I'm still fuzzy on sketch projections, but I'll keep at it.
Thank you again for taking the time to help out,
thecapper
