Solved by Pavel_Holecek. Go to Solution.
@Anonymous
When posting you should always indicate the Inventor version you are using.
In addition we really don't have a clue how your model was put together. Can you share the model structure so we can review it and offer suggestions.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @Anonymous were you able to figure out how to rotate your V-belt?
Can you attach your pulley assembly for better investigation using the parameters that you are working with?
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
V-Belt generator inserts pulleys with transmission ratio. There is enough to position pulleys and then makes V-Belt component Flexible.
All pulleys are rotating but not the belt - it is the same for all belts and chains generators.
Let me know if you need more info
Hello have 1 more questions
Y I can't any description on pulley or belt
Or how should I add it or by changing dia or groove or type updated with that....
