Inventor Forum
How to erase FEA files from assembly?
19 REPLIES 19
Message 1 of 20
Orest_iy
14518 Views, 19 Replies
I used to use the Stress Analysis feature at my assembly.
Now I have copied it to another project and do not need this FEA info at copy.
I cannot just delete AIP folder since  Inventor claims of missing FEA files while opening.
Please advise how to erase those files info from this assembly file?
Best regards,
Orest Yavtushenko
19 REPLIES 19
Message 2 of 20
henderh
in reply to: Orest_iy
Hi Orest,
  There are two ways that are provided here: FEA / Vault thread
  Add them here for your convenience:
1)  Delete the links in the modeling environment via Tools tab, Links command and save the model file
2)  In the Stress Analysis environment, in the Stress Analysis Settings dialog (not the Simulation properties dialog) uncheck 'Create OLE Link to Result Files' and save the model file
Hope this helps...
Thanks! -Hugh
Hugh Henderson
QA Engineer (Fusion Simulation)
Message 3 of 20
Orest_iy
in reply to: henderh
Yes
both ways are working
Thank you for advice
Orest Yavtushenko
Message 4 of 20
I copied the design from a previous project in vault.I had put the copied Fea files in a separate folder, but my Vault admin deleted it.I am not able to delete the FEA associative files.The links command is not selectable. And the environment option does not work either.Now every time I open the file I am asked if I want to locate the Fea files.Really annoying.
Message 5 of 20
johnsonshiue
Hi! If I understood the issue correctly, you are prompted for .fea result files. It is because there was a FEA study in the Stress Analysis environment linked to a result file. Now, the result file is missing, the study will either need to be rerun or deleted. You might need to enter the FEA environment, rerun the analysis or delete the study and save. After that, Inventor should not prompt you for the result file.
Many thanks!
Software Test Engineer
Message 6 of 20
Cadmanto
in reply to: johnsonshiue
I have this same issue as the link in Hugh's solution posting.
I inherited these assembly files.  These assemblies were done at a different location so the file pathing was different as shown below.  The FEA files were not transferred here so like others, when I go to try and check into the vault, I get the errors shown below.  Also, it prompts me to resolve the links for these files as well when I go to open the assembly.
Now, following the solution, it is suggesting I go to the Tools tab and select the links command, except in my case it is greyed out.  Now what????
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 7 of 20
johnsonshiue
in reply to: Cadmanto
Hi Scott,
Did you try the second solution Hugh provided (change the setting in FEA environment)?
Many thanks!
Message 8 of 20
Cadmanto
Hi Johnson,
I can't.  The FEA was done off site in a totally different location.  I have no access to that site or files.
So, I am stuck with these models that keep prompting me for the FEA files.
There is nothing in the browser from a 3rd party, nothing visible to delete.
I really hope I am not stuck with this the way it is.  I am trying to get these files in the Vault.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 9 of 20
johnsonshiue
Hi Scott,
If you enter Stress Analysis environment, delete the study, save and close the file, does it still prompt you on open? If yes, I guess this could be a corrupted assembly. You might need to demote all components to a subassembly (but the iProperties might be lost). Essentially, recreate the assembly quickly.
Many thanks!
Message 10 of 20
Cadmanto
Hi Johnson,
Thank you for your help.  Demoting the sub-assemblies is easier said then done.  I need to keep the integrity of the assembly.  I am thinking at this point, maybe try contacting the company that created this assembly and see if I can get my hands on the FEA files.
Because as you can see from below, there is nothing to delete as per your suggestion.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 11 of 20
johnsonshiue
Hi Scott,
Unfortunately, this means the assembly is corrupted. You might need to demote the components to a new assembly.
Many thanks!
Message 12 of 20
eliza.dawson
Is it possible the reports are in a higher or lower level assembly?  I just ran into the same problem.  When the prompt window opens up it tells you which assembly the reference is in.
Message 13 of 20
Cadmanto
in reply to: eliza.dawson
The reports actually end up being in a part file.  When I open said part file those same windows come up looking to try and connect with the analysis reports.
Not seeing any reports to delete in the part browser.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 14 of 20
I was having the same problems.
Deleting the .fres file link didn't initially work as I'd previously deleted the FEA study.
On opening the assembly the system is still looking for
.fins
.fsat
.ftes
.fwiz
.fmsh
etc.
The solution is recreate an FEA study and then uncheck the OLE box.
This enables the deleting the link / unchecking the OLE link box solution to work.
Message 15 of 20
Guys is there any way to break/delete all the links in one click instead of just going one by one? (I'm talking about tools->Links)
We don't work with vault
Manuel Campos Costa
Message 16 of 20
Also, what could happen if I set the option to not create OLE Links ?
Manuel Campos Costa
Message 17 of 20
That is what I do.
AFAIK, there is no way to delete all at once - once created you have to delete one-by-one.
Message 18 of 20
And what are the consequences?
Do I need to rerun the study if nothing changed just to check results?
Does it delete the study settings (loads, fixtures)?
Basically what is the functionality of that link ???
Do I need to uncheck that box on every study scenario or every part/ assembly or is there any option in "Applications Options" that disables that forever.
Thank for the help ! 🙂
Manuel Campos Costa
Message 19 of 20
Constraints and loads remain in the definition, only the results are not retained, so if you close the file and later open it again - you have to re-run the analysis even if no changes were made.
Message 20 of 20
Oh ok now I see, I don't want that behaviour because some of my simulations take a lot to finish.
Ok I will stay with breaking the link one by one.
Does anyone knows of an ilogic that can do that? Break all OLE links?
Manuel Campos Costa
Autodesk Customer Advisory Groups
