I have a part that has multiple radii that are of the same value. Is there a way to have a single radius callout that has arrows to my three radius locations?
Solved by andrewiv. Go to Solution.
If you create a leader text instead of a radius dimension you can right click on it and select "add leader" then you can add as many leaders as you want. You will want to insert your model parameter for the radius into the leader text so that if it changes the text will update.
Andrew In’t Veld
Designer
Welcome to the Autodesk Community @Anonymous !
Great to see your questions here on Inventor Forum. Hope you will find a solution soon.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
