Inventor Forum
how do you flatten this circle into a straight piece?
7 REPLIES 7
Message 1 of 8
1617 Views, 7 Replies
How do i flatten this circle part so it is a straight bar?
How do you measure the length while it is in a circle shape?
Thank you
Damian
7 REPLIES 7
Message 2 of 8
mdavis22569
the length would be Pi x Diameter ... if you have a circle part in Sheet metal you'll need to put a cut or RIP (command) in it to be able to flatten. It can't unless it knows there is a break in the solid
Mike Davis
Message 3 of 8
JDMather
This might be an easier way to create the part.
Message 4 of 8
in reply to: JDMather
Thank you
I worked out how to unfold the part so i could apply a pattern.The end result came very close.Can you show me how to make a pattern which fits equally.I have a 0.603 measurement when they are refolded.It is very close but if there is a way to apply the pattern to fit equally or with parameters it would be easier as i guessed the number in the pattern
The file is 1.89mb....could there be a way to model  in which a same look but smaller filer size
Thank you
Damian
Message 5 of 8
Are there ways to get correct pattern in this model.Where the part joins it is very slightly out.Can equations be used to figure out correct spacing?
Message 6 of 8
mdavis22569
I'm on an older version at work so I can't look... can you post a screen shot and I might be able to help
Mike Davis
Message 7 of 8
in reply to: mdavis22569
please see attached
When the part is refolded the measurement is 0.603 (small variance) whereas the other lengths are 0.6
Is there a method in which you can have all of the pattern equal in distance?
Does this require parameters or formulas?
Damian
Message 8 of 8
JDMather
When you bend metal it stretches.
What is the tolerance of your manufacturing process?
