Inventor Forum
hole note error
3 REPLIES 3
Imtas_as
262 Views, 3 Replies
hole note error
Hole note does not work when holes are edited with thicken/offset. It will write the original diamter, not the new one. Just to let you guys know.
3 REPLIES 3
blair
in reply to: Imtas_as
The Hole Note and Hole Table only read data created with the Hole Feature tool. If it's changed with the Thicken or using the Extrude Feature, these actions will not change the basic Hole meta-data. This is as designed.
Delta Tau Chi ΔΤΧ
Imtas_as
OK, I suspected that, but it works fine with extrude.
mrattray
Why would you wan to edit a hole with thicken/offset instead of editing the hole feature directly?
Mike (not Matt) Rattray
